Building a high HP, dependable, rotary
Old Apr 1, 2010 | 09:08 AM
RXTASY57's Avatar
Viper Eater
Here is what I am proposing:
-4X2000cc injectors
-2XBosch 044 pumps
-E85 fuel
-ALS Apex and side seals
-Meth injection
-T72 BB Turbo
What am I missing?
Old Apr 1, 2010 | 09:37 AM
Indian's Avatar
It wasn't me!!
a good tuner and lots and lots of prayer
Old Apr 1, 2010 | 10:57 AM
lastphaseofthis's Avatar
My job is to blow **** up
good luck with 2000cc primary's.
Old Apr 1, 2010 | 11:34 AM
fdfreak's Avatar
A well built, solid motor.
Old Apr 1, 2010 | 12:21 PM
RXTASY57's Avatar
Viper Eater
Have that covered! Injector Dynamics Injectors
Old Apr 1, 2010 | 07:54 PM
killalot13601's Avatar
Or a 2500rpm idle. If you want serious power it must be a track car right?
other option.... LSX
Old Apr 1, 2010 | 09:05 PM
Jay7 Nyc's Avatar
What EMS are you going with? I'd stick with Stock seals or NRS seals once tuned well and also balance the internals...
Old Apr 2, 2010 | 08:54 AM
RXTASY57's Avatar
Viper Eater
Yeah....hoping for at least 600 RWHP.
From everything I have heard, ALS seals are the bomb!
I have considered a V8, but putting out 600 RWHP even with a V8 would be challenging. I know more abour rotarys than I do boingers too.
I have a Haltech E6K in there right now. Considering going Microtech.
The car is already caged and has had the axles upgraded.
Oh! Yeah..... I will balance the internals as well.
Old Apr 2, 2010 | 09:44 AM
Gene's Avatar
10 lb. boost, 5lb. bag
20B! With 50% more displacement you should make 50% more power at a given level of boost, so you can hit your desired power level with a less high-strung setup. It won't be cheap, but over the long run it will probably be cheaper.
What is this going to be used for?
Old Apr 2, 2010 | 09:52 AM
PvillKnight7's Avatar
A 600hp ls1 would be more dependable than a 600hp 13b
Old Apr 2, 2010 | 10:55 AM
RXTASY57's Avatar
Viper Eater
Drag Racing....I had a 20B all ready to put in it a couple years ago and had to sell it because I owed the IRS money.
I know there are plenty of guys making this kind of HP on 13b's.
I think using E85 will help greatly because of the cooling properties. That combined with unbreakable apex seals and a balanced, tuned motor should get me where I want to go.
I was thinking about dowling and pinning, but if it's tuned properly, I shouldn't need that.
One other aspect is, I should be able to pass emissions with this and drive it on the streets!
Old Apr 2, 2010 | 11:26 AM
Monkman33's Avatar
Goodfalla Engine Complete
Um..... wow.....
aux injection
good build
great tune
Old Apr 2, 2010 | 01:59 PM
Gene's Avatar
Doesn't exist
Old Apr 2, 2010 | 02:21 PM
RXTASY57's Avatar
Viper Eater
Doesn't exist
According to some very knowledgable people right here on this forum, it does exist! That is why I choose ALS.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
