gas spraying from motor
Old Mar 28, 2010 | 11:38 PM
crazeelatin's Avatar
NJ gas spraying from motor
i have an 89 rx7 gtu ... and it has a major gas leak from the motor .. the gas is spraying out of the motor like crazy what can i do ..
Old Mar 29, 2010 | 09:19 AM
Pele's Avatar
Right near Malloy
Which side is the fuel leaking from? Driver's side or passenger's side?
The two fuel lines go to the engine on the Driver's side just in front of the oil filter.
They cross over as hard lines to the passenger side and connect to the fuel rails.
Common problem is the Fuel Pulsation Dampener on the passenger's side. It looks like a little white or yellow cap. You can notice it if you stand in front of the car and look to the left of the alternator. It's below the manifolds.
Old Mar 29, 2010 | 11:30 AM
rxtasy3's Avatar
i agree. i've also read that it's the cause of most engine fires.
Old Mar 29, 2010 | 04:37 PM
RotaryRocket88's Avatar
Top Down, Boost Up
First of all, don't drive the car. Pull the upper intake manifold and jump the yellow fuel pump test connector on the passenger shock tower. Turn the key to the 'ON' position, and the fuel rail will become pressurized. Find the leak and replace the hose, PD or whatever the source is.
Old Apr 2, 2010 | 02:20 AM
well i found out were its leaking from ... its in the middle of the secondary fuel rail and the back fuel injector ... do i have to switch the whole thing or just the fuel injectors....
Old Apr 2, 2010 | 10:45 AM
mazdarotaryfan's Avatar
probably just a bad rail itself (very rare) our more likely bad orings on the rear injector.
Old Apr 2, 2010 | 02:50 PM
Top Down, Boost Up
If it's leaking around the top of an injector, replace the o-rings and lower grommets at the same time. http://www.mazdatrix.com/c-6.htm. Middle of the page.
incubuseva
14
Sep 3, 2015 12:37 PM
PhillyFC
Aug 21, 2015 06:36 PM
smikels
Aug 18, 2015 01:26 PM
