Pretty much stock, 226whp - 221 torque
Old Mar 28, 2010 | 05:18 PM
sen2two's Avatar
Rx2 > FD
The drop off is due to boost dropping off in the upper RPM and causing a break up due to over fueling and water meth mix. Not sure of the AFR or EGT's. Didnt have anything hooked up. I will be going back with a upgraded internal wastegate and maybe an safc to try for 250whp.
Minimal things done...
Stock turbo
Stock motor (never opened, unknown milage)
Stock ECU (chipped by pan-speed, No idea what has been changed???)
Stock top mount intercooler (modified by me)
Home made intake, 2.5"
Home made 3 inch exhaust/DP
Port and polished manifolds and TB by me
1st run: 3rd gear with water/meth
2nd run: 4th gear with water/meth
3rd run: 3rd gear no water meth
Old Mar 28, 2010 | 06:32 PM
rotordad's Avatar
The Big Ugly!
Congrats! Good numbers man.
Old Mar 28, 2010 | 07:49 PM
sen2two's Avatar
Rx2 > FD
1st run:
2nd run:
Old Mar 28, 2010 | 07:54 PM
sen2two's Avatar
Rx2 > FD
thanks!
I was pretty impressed. And im very confident that with a new wastegate with capabilities of holding boost to the 7k+, instead of dropping off and causing the break up at 5500, i would hit around 250.
Old Mar 28, 2010 | 10:59 PM
rotordad's Avatar
The Big Ugly!
It would be nice to see you hit the 250 mark on minimal mods, good luck!
Old Mar 29, 2010 | 07:16 PM
junito1's Avatar
F**K THE SYSTEM!!
How much psi?
Old Mar 30, 2010 | 08:32 AM
sen2two's Avatar
Rx2 > FD
11psi but dropping off hard after 5500rpm to 6psi. thats the dip in power...
the 226.9 whp run was done it 4th gear, so i think it hit 13-14psi before dropping off also.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
The1Sun
Mar 18, 2018 11:08 PM
sYnth.
Aug 19, 2015 06:27 PM
