Haltech a few install problems, [fd3s]
Old Jun 19, 2002 | 12:58 AM
Bacon's Avatar
IRS 4 Life
ok so i got it all abt 90% wired up the other day, but ran ito a few problems...ok
fist when your doin the injectors it lists them as 1 pri then 2 pri then 3 sec then 4 sec.....wich one goes to wich rotor? if 1 ans 2 are in order dose that make 3secoindary in front or rear rotor?
2 ok i hacked up my harness b4 i total read the install and on connector 3d to the violet/white wire from the haltec...ok how does this connector run the fans? where dose it hop into a diff harness b/c i have ecu connectors 3 and 4 outas the car and never disconnected them from anything that jumps into the fan relay circurtry
thanks guys
Old Jun 19, 2002 | 01:09 PM
RETed's Avatar
It doesn't matter, cause when you run staged mode, the banks all fire in batch.
-Ted
Old Jun 19, 2002 | 11:30 PM
BLUE TII's Avatar
Rotary Motoring
Well, the term "batch" may be misleading in this context. This is what I thought...
In NA rotaries the E6K fires inj. in "batch-fire", where the 2 banks (1 and 2 = bank 1; 3 and 4 = bank 2) of inj. are fired alternately.
In turbo rotaries don't you use "staged" inj. where bank 1 (inj. 1 and 2) fires all the time like in "multipoint" mode and bank 2 (inj. 3 and 4) is enabled at a set boost pressure?
If so, it would matter that 1 and 3 were on one rotor and 2 and 4 on another, right?
Now, I have a question. Can you set up "sequential" injection like in advanced features using "injector phasing" and use "staged" mode as well. I am new to Haltech stuff.
Thanks, Ian.
Old Jun 20, 2002 | 11:45 AM
RETed's Avatar
Now I'm confused...
I always thought "batch" was firing all the fuel injectors at the same time?
I know this is not possible as of this moment with the E6K.&nbsp You either got sequential operation or staged - you can't have both.
-Ted
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
