TEMP, OIL, and RPM gauges dont work!
Old Mar 26, 2010 | 11:47 AM
andresj's Avatar
bone stock
Hey so before i had the accident with my car all my gauges worked. When I did the swap to the new shell now none of these work. What should I look for? I hope I can get these things done today! Would there be a problem if my original car was and had S4 Sport model cluster and all the things I transferred to has a S4 TurboII cluster?
Old Mar 26, 2010 | 11:51 AM
finishline's Avatar
Not Even Foo
wow, that's weird. good luck with that man.
Old Mar 26, 2010 | 12:25 PM
rotary_bünta's Avatar
Rotary Retard
no trying to thread jack but outta now where my speed o meter and milage stop working. Tach and oil and batt all work.. very odd.
Old Mar 26, 2010 | 12:39 PM
andresj's Avatar
bone stock
I think yours is on the transmission I don't know though I hope someone could help soon
Old Mar 26, 2010 | 01:47 PM
The CzAR's Avatar
Death or Glory
Your meter fuse is probably blown. It controls the instrument cluster. First determine if it's blown, then you can start to pinpoint what's causing it to blow.
Old Mar 26, 2010 | 02:06 PM
andresj's Avatar
bone stock
Cool thank you I will go check that out right now. What if the meter fuse is not blown?
Old Mar 26, 2010 | 02:37 PM
andresj's Avatar
bone stock
How do I know which one is the meter fuse my car doesn't have that black lid with the sticker on it to show you which fuse is which.
Old Mar 26, 2010 | 02:47 PM
88redturbo2's Avatar
ita going to be third from bottom and third row, 7.5amp
scroll down the the fuse panel picture: https://www.rx7club.com/showthread.p...72#post5131072
Old Mar 26, 2010 | 03:05 PM
andresj's Avatar
bone stock
cool thanks. it was blown
Old Mar 26, 2010 | 03:40 PM
The CzAR's Avatar
Death or Glory
replace it and see how long it lasts. pay close attention to see if it blows when you shift into 5th or reverse. those two switches are tied into the meter fuse and can be the culprit sometimes. A bad reverse switch on my car kept blowing the meter fuse.
andyvideopro
Aug 20, 2015 10:55 AM
LMBTG
Aug 15, 2015 01:43 PM
