Need clutch replacement
Old Mar 23, 2010 | 01:24 PM
zracin's Avatar
2 stroke oil
I have a'90 convertible that has had some work done to it by the former owner( whom i cant get hold of) I need to replace the clutch, but am unsure of what tranny I have, or if it even matters. He did tell me that he has a LSD from an '88 TII, but Is there any way for me to know if he just swapped out the pumpkin of the whole tranny? is there anything I can look at to tell if its an entire TII tranny? What clutch do you recommend. I was looking at exedy organic clutches, just due to their price. any recommendations?
Old Mar 23, 2010 | 10:10 PM
farberio's Avatar
NASA-MW ST4
exedy is fine for clutch.
A TII trans will have a window cover to look at the clutch area on the bottom near the engine side of the trans, the N/A does not.
The TII trans has a removable bell housing, the N/A does not.
The TII trans has two fill plugs, I am pretty sure the N/A only has one.
Old Mar 24, 2010 | 06:52 PM
zracin's Avatar
2 stroke oil
Much appreciated
A tii trans will have a window cover to look at the clutch area on the bottom near the engine side of the trans, the n/a does not.
The tii trans has a removable bell housing, the n/a does not.
The tii trans has two fill plugs, i am pretty sure the n/a only has one.
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 19, 2015 06:27 PM
