What turbo/turbos would you use on a 20B FC!?
Old Jun 18, 2002 | 08:59 PM
crazydriving.net's Avatar
main goal for this fc is to be the fastest streetracer around... simple as that... proving that rotary kicks ***!
around here everyone is talkin **** about rotaries... they have even never heard of a 20b engine...!
this is one is the engine of the badest cars around scandinavia...
its a supra...
fitted with GT80
fitted with GT72
Old Jun 19, 2002 | 06:19 AM
jspecracer7's Avatar
1JZ powered
T-66
Old Jun 19, 2002 | 09:35 AM
Greg's Avatar
If you are liking innovative turbo then go witha GTB88 or a Turbonetics Thumper 88. T66 is too small if you are trying to make sick hp. Im a dealer for both manufactures also by the way . They are expensive but worth the money.
Old Jun 19, 2002 | 09:43 AM
RETed's Avatar
Triple turbo the bitch!
Triple GT-2835's are good for 900hp.
You get the ultra-quick spool up of the smaller turbos, so theoretically you'd get a wider powerband.
-Ted
Old Jun 19, 2002 | 01:25 PM
-Ted
this i actually what iam thinking about....! even thought about triple 3037? That would make some crazy hp?
What about a T101? Is this is what you are fitting your 20b Greg?
Old Jun 19, 2002 | 03:30 PM
Greg's Avatar
Im going to be using a smaller Compressor 91 mm as opposed to the 101 mm. There is a racer from Philly making 1300+ HP with the T100 and 3 rotors Its all about how much money you want to spend. How much are you looking to spend on the turbo system?
Old Jun 19, 2002 | 03:57 PM
im not sure yet...! first we are gonna go with the stock turbos... then were are gonna do the turbo setup..
the point is that this will be a 'streetcar', it would be needed to be able to drive on the streets. Not a everyday car but we need to be able to drive it on public roads. How about your car, will it be a full blooded dragcar or a 'streetcar'?
Have also been thinking about a triple 3037 for less lag...
Old Jun 19, 2002 | 04:24 PM
RETed's Avatar
Those turbos are too big if it's one per rotor.
That turbo is too big, even for a single on a 20B short of a 100hp shot to get it spinning.
-Ted
Old Jun 19, 2002 | 04:53 PM
-Ted
There are a 13 b with twin 3037 in Japan...I have some pics of it if you havent seen it.
And that T101 is actually used on a 13b engine, but its a dragster though...
here is the 13b with the twin 3037...
Old Jun 19, 2002 | 05:31 PM
Greg's Avatar
Noone knows for sure what turbo Dalton is using. You cannot tell turbo size from the outside. He could be usind the Thumper or GTB frame (huge) with only a 80 mm compressor wheel. Ive sold a T100 sized 80 before and the only difference is the compressor. Here is a better question. What kind of pwer are you trying to make?
Old Jun 20, 2002 | 07:10 AM
Dragon's Avatar
20B N/A Wide Body FC3S
I'd run a T-76 with a 1.3 Q trim exaust and decent side port, should be able to get 650-700hp out of that with out it blowing up... and should still be quite streetable.. I wouldn't worry too much about boost lag with the 20B. It should putt around just fine with the extra low end tork and power from that extra rotor...
Old Jun 20, 2002 | 08:18 AM
13BAce's Avatar
On a long vacation
How about this one?
Old Jun 20, 2002 | 09:31 AM
Greg's Avatar
t76 is like a to4e for the 3 rotor great boost responce and good hp. Id still use something bigger though (thumper or GTB family) but that might be cause I am into sick HP and drag racing.
Old Jun 20, 2002 | 11:26 AM
RETed's Avatar
You ever seen the dyno curve on those things?
-Ted
Old Jun 20, 2002 | 04:35 PM
-Ted
about 750hp i think... with 20mm bridge porting...
but what about a tripple 3037? why wouldnt the 'extra' rotor handle the last 3037? if it worked on the 13b?
Marius
Old Jun 20, 2002 | 07:50 PM
RETed's Avatar
It makes very little power down low.&nbsp If you want a peaky power band, go for it.&nbsp I thought drag racing was all about getting to the far end the quickest.&nbsp This usually means the broader the power band, the quicker the car.&nbsp The triple GT2835's should do 900.&nbsp They should also kick in very LOW RPM's - I peg them boosting as low as 3,000RPM.&nbsp Run the right A/R, and you get one helluva power band and should BEAT the GT3037's in a drag race.
-Ted
Old Jun 21, 2002 | 04:49 AM
HWO's Avatar
HWO
inteligent extratarestril
-Ted
Yeah i have, and one of the dumbest responses i have seen on this forum followed it, i recall it being along the lines of "........if i raced that car and we were limited to 4000rpm, i'd walk all over it..........."
.........and that my friend, is what gearboxes and diff's are for
Old Jun 21, 2002 | 10:04 AM
-Ted
yeps... sounds very good! Anyone know the name of the company that made the triple 2835? Maybe they can make me a good exhaust manifold.
Old Jun 21, 2002 | 01:48 PM
RETed's Avatar
Sorry dude, just because you can't do Excel graphs and prove your point, don't need to make excuses cause you can't argue your side of the debate better.
-Ted
Old Jun 21, 2002 | 08:58 PM
HWO's Avatar
HWO
the rev limiters are set at 8000+ for a reason, we dont all think we are driving 10 litre V8's which redline at 4000rpm
WTF are you one about drawing excel graphs? that car would straight out SPANK yours in race, its not 100% streetable - was it ment to be? erm NO
Duc852
Sep 22, 2015 03:49 AM
