Drifting Discuss Drifting and drifting techniques here.
differential welding help
Old Mar 22, 2010 | 11:52 PM
Marck's Avatar
CA differential welding help
alright so i stocked up on 3 differentials. my old stock one (open 3.90) bought on for 45 (welded 3.90) and now im getting a 4.1 but open. my question is does anyone know what parts of the differential i have to weld so it turns in to a cheap ghetto *** LSD? pictures would be great thanks!
Old Mar 23, 2010 | 12:41 AM
Zenki FC3S's Avatar
\\TRASHTALK//
there are four spider gears, they are what need to be welded. weld the teeth where they meet the adjacent gear.
i have pics of a welded clutch type T2 diff, if youre interested in welding a clutch type
Old Mar 23, 2010 | 10:04 PM
NoPistons!'s Avatar
Tango Down
"there are four spider gears"
Pull your ring gear off, wrap the bits you're not welding with wet towel and make those spider gears vanish under multiple beads of filler.
Not kidding. Weld the gears to themselves and to the diff body WITHOUT any gaps. If you see any gears or gap between the diff body and gears, fill that **** in.
The trick is to not leave ANY shear points.
I would never weld something that can be used and rebuilt.....aka oe clutch type but it's all up to you and your budget. Viscous? Weld the **** out of it. You'll see how after you pop it out of the case.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
MILOS7
May 9, 2016 06:39 AM
