testing compression
Old Jun 18, 2002 | 07:37 PM
neevosh's Avatar
The Dude Abides
testing compression
What's the correct procedure for testing compression? I followed the instructions in the manual, but I'm not sure I'm doing it right.I screwed the tester into the trailing plug and cranked the engine. It jumped up to 45psi, 70psi, then 100, moved around a little but stayed around there after cranking it a few more time. About same on the other rotor but it only hit 90psi.
Old Jun 19, 2002 | 12:39 AM
neevosh's Avatar
The Dude Abides
Nevermind, I found it.
Old Jun 19, 2002 | 06:32 AM
jspecracer7's Avatar
1JZ powered
so post the thread...I need to do this too
Old Jun 19, 2002 | 02:00 PM
c00lduke's Avatar
like neevosh mine goes like 30-30-30 and stop at 90 no matter how much more i crank it, but that was on a cold engine.
Old Jun 20, 2002 | 12:58 AM
neevosh's Avatar
The Dude Abides
Here's the info I used. Haven't had a chance to retest it yet. http://www.rx7turboturbo.com/robrobi...ompression.htm
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
