Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Map sensor reading
Old Mar 21, 2010 | 11:30 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
Map sensor reading
My boost gauge and the map reading from the sensor is a little awkward.
The map reading doesnt read higher then 12psi. But my mechanical boost gauge is showing up to 14-15psi. They both read the same psi as it climbs, had a passenger check them both to see if they are both reading the same -12inhg to 12psi, but after that the map sensor just stops reading while the boost gauge is still climbing.
I look at the datalog and you can see the map sensor reading climbs, then just goes flat once it reaches around 12psi.
I though the map sensor max range was 16psi? Is it my map sensor?
Old Mar 21, 2010 | 01:22 PM
turbo2ltr's Avatar
Do you have a FCD installed?
Old Mar 21, 2010 | 08:59 PM
None that i know of
Old Mar 22, 2010 | 10:31 AM
turbo2ltr's Avatar
Its a 2 bar map sensor so it reads +/- 1 bar, it should read up to 14.7 psi.
Cracked vacuum lines?
Old Mar 22, 2010 | 02:23 PM
drifting in drifting's Avatar
I had that happen to me . I also have an Apexi ebc wich is consistant with my gauge but not with my factory map. Is the factory sensor that far off??
Old Mar 22, 2010 | 02:40 PM
Nick_d_TII's Avatar
+1
I see 11-13 on the Gauge, but like ~9-11 on the ecu.?....
Old Mar 23, 2010 | 05:18 PM
fc3schick87's Avatar
Rotary Addiction
what is the source of the vaccume line. is it the ones behind the throtle body? which ones are you using. are you using Ts.
maybe the map sensor is bad. use the FSM and run a check on your map sensors.
what about the sensor itself, is it an n/a sensor or tii.
how is the wire harness. are you getting full volts/readings in the line all the way to the ecu.
idk, this is why i am asking, to ask yourself. stock harness can have issues in it, bad connectors weak signals.
just a thought.
Old Mar 23, 2010 | 08:01 PM
Ill try changing the main vac line, right now its the nipple near the acv, but I have that blocked off. My boost gauge is run off of that same line. I replaced all vacuum lines with new ones. Its a 370 map sensor so its the right series for the ecu. I was going to check the map sensor last weekend, but I had to change my cousins valve seal in his civic, so I will check that this weekend.
Old Mar 26, 2010 | 02:59 PM
2RotorSpeed's Avatar
rottary89
Ok, question for all of you...
If you have the car OFF, and turn ignition ON, then check the MAP sensor reading on your Palm... does it read 0 ???
Mine reads 1.3 inHg with ignition ON and car OFF. I tried different MAP sensors and they ALL read the same value, so there is no way the sensor itself is wrong. Now I'm checking the voltages at the sensor and ECU, and the power voltage to the sensor. Also, when I compare the boost gauge reading with the ECU reading, the values are ALWAYS off by about that 1.3 value... at least during vacum conditions.
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Snook
Aug 15, 2015 08:18 AM
