Power FC UN Mapped
Old Mar 21, 2010 | 02:15 AM
Benslidin's Avatar
Fata**7
UN Mapped
so i took my car to be tuned and they said the power fc isnt mapped but my friend was running it in his car how do i re map it?
Old Mar 21, 2010 | 05:25 PM
thewird's Avatar
He probably means its running the base map/tune that comes with the PowerFC. It is not a good idea to use this map and you should get your car tuned.
thewird
Old Mar 21, 2010 | 05:49 PM
Benslidin's Avatar
Fata**7
no becuase it wont even allow the car to start
Old Mar 21, 2010 | 05:53 PM
thewird's Avatar
Are you running stock primary injectors? If so, the base map should allow the car to start and run. If you bought the PFC used, it may be tuned and not work for your car. You can reset the PFC to the base map by going to ETC --> reset base map (i think thats what its called), highlight yes and press next. Then key off the car, wait a bit and key it back on. The map should now be the base map, whatever was on the pfc before is lost though. If your car still doesn't start, its probably flooded and/or needs new plugs.
thewird
Old Apr 6, 2010 | 01:02 AM
Benslidin's Avatar
Fata**7
thewird
im going to try this i got the car to start today and run but is very rich
Old Apr 6, 2010 | 01:03 AM
Benslidin's Avatar
Fata**7
thewird
oh yeah i put the 850-850 ib and it stared now im trying to figure out the really rich problem.
Old Apr 6, 2010 | 06:15 AM
creature546's Avatar
my 850-850 combo runs at about 11.0-11.5 AFR at idle...thats the best I could get. something yo are just going to have to deal with
Seth
Old Apr 6, 2010 | 07:34 AM
thewird's Avatar
Did you set the primaries to 64.7 percent?
thewird
Old Apr 6, 2010 | 12:04 PM
Benslidin's Avatar
Fata**7
thanks i will put those in
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
