Tegheim - Home made 4 Rotor Wolvo project
Old 03-16-10, 04:15 PM
tegheim's Avatar
Hi, where unsure if I should post a project thread, but gusfd3s here pushed me
I'm trying to build a car the way I want.
The car is an Volvo 142 -73. They are rather common i Sweden, but all of them are piston-engineed.
It started with a simple 4-link-build. But now it all has got out of hands...
I will post as much pictures as possible, but there is alot old pictures so I also link my older swedish project-thread so you all can se my progress-pictures.
I let the pictures talk for them self at first. Visit my album at Photobucket, to much to upload!
All work is done by myself.
Regards Tegheim
http://s815.photobucket.com/albums/z...20Wolvo%20142/
Some teaser...
Old 03-17-10, 07:05 AM
tegheim's Avatar
Random pictures...
Old 03-17-10, 08:51 AM
kiwi from downunder..
blwfly's Avatar
wow totally amazing
Old 03-17-10, 11:17 AM
MountainScreamer's Avatar
Holy crap this thing is gonna be cool!! This is very impressive.
By the way, what transmission is that?
Old 03-17-10, 12:09 PM
datfast1's Avatar
That will be a sick project. Got some estimated time on the finish build, 1 to 2 years maybe?
Old 03-17-10, 01:36 PM
tegheim's Avatar
The gearbox is BMW M3/328 E36 5gear with rx7 s4 boltpattern.
I have no idea how long time the project will take actually. Will soon start to engineer the 4-rotor-shaft.
Meanwile I will fix and measure the new front suspension and frame.
Glad you like it
Old 03-17-10, 04:30 PM
Thanks for clarifying on the transmission. I've never seen a BMW one before so I was confused.
When you machine it, could you give specs on the eccentric shaft, like what material, will it be in a couple pieces? Who did the drawings for it?
I've always wanted to machine one but haven't been able to get any exact dimensions.
Old 03-17-10, 09:28 PM
In a Bucket
w.sen's Avatar
This is amazing keep up the good work!! Was there any mods to make the bmw tranny fit ?? Or did it bolt right up??
Old 03-17-10, 09:35 PM
RAWR
OneRotor's Avatar
Epic build. Subscribed.
Old 03-18-10, 01:08 AM
tegheim's Avatar
All drawing and machinework is made by myself. I have made the drawing in Inventor, and then I will machine it with MasterCam in a Femco CNC-Lathe, and a Matsuura Mill.
All dimension and so on will be releaved as soon as I know it works. I will not have any secrets, but don't want to make peaople build something that doesn't work.
No, it doesn't fit bolt on, I cutted of the boltpattern from a S4-gearbox, about 70-80mm wide I think. Same with the BMW-tranny. Then when all egdes where in line, I fixtured into a backplate of an 13B and weldet it together. Sorry, didn't take any photos of that...
Thanks
Old 03-18-10, 06:41 AM
StavFC's Avatar
Amazing stuff, all the best cars come from Norway and Sweden.
I hope to see this in action at Gatebil sometime when its finished!
Old 03-18-10, 11:23 AM
Cool.
The setup I'm currently using is ProEngineer with OneCNC for the code on Haas CNC mills and lathes.
Do you have any specifications for the 4-link?
Old 03-18-10, 01:34 PM
tegheim's Avatar
I hope I will get to Gatebil also... have been there 4 years but only with a cold beer in my hand
Cool.
I maybe have the drawing of the 4-link left at the CAD-computer, can check tomorrow.
Old 03-18-10, 04:11 PM
$ ain't everything, rite?
Bugeye RX's Avatar
This is serious frigg'n business here!!!!!!!! I'll be following this one for sure. Very cool.
Old 03-18-10, 07:45 PM
Chuck Norris FB's Avatar
Question
Just curious, do you plan on fabricating the 4 rotor e-shaft your self or have some third party machinist do it for you??
Old 03-18-10, 07:48 PM
Learned alot | Alot to go
CrackHeadMel's Avatar
Got a pic of the shaft print with dimensions ?
Also, did you proof out the front end geometry in inventor swell?
Old 03-19-10, 03:08 AM
tegheim's Avatar
Thanks
Yes, I'm doing all the work my self. Drawing, machining, designing and building The only thing on the E-shaft I will give away is hardening, and polishing.
I have the print with dimensions in front of me right now It's my own drawing on the picture I posted
How do you mean proof? :S (Dumb Swede)
Old 03-21-10, 01:42 PM
tegheim's Avatar
No big news really, have welded the frame totally now, and it will now be ready to be put'ed in the Wolvo.
Chaos?!
Finished
This week I will order the material to the e-shaft for the 4-rotor. Maybe I can start little next weekend to machine it
Regards
Tegheim @ Mooseville Performance
Old 03-21-10, 01:49 PM
Are you going to grind the eshaft inhouse aswell? or are you brning it into size on a lathe?
Old 03-21-10, 02:37 PM
tegheim's Avatar
What do you mean? My english you know
Don't know what "grind" mean... can you expalin i "english for dummies"
Old 03-21-10, 02:38 PM
Tango Down
NoPistons!'s Avatar
Subscribed.
4 rotor gives me the ultimate bonar.
Old 03-21-10, 02:52 PM
blwfly's Avatar
[QUOTE=tegheim;9882587]What do you mean? My english you know
Don't know what "grind" mean... can you expalin i "english for dummies" [/Q
grinding is poor way to machine something ..
Grinding (abrasive cutting), a method of crafting
if u get stuck on words i find Wikipedia the best.
http://en.wikipedia.org/wiki/Main_Page
nice frame are u a automotive engineer?
Old 03-21-10, 03:23 PM
Similar to the method of putting lobs on a camshaft, however judging from your repsonse.. your not
G'luck with the build, cant wait to see more pics
Old 03-21-10, 03:54 PM
tegheim's Avatar
Hmm, not sure we understand eachother still. Let's do this, I tell you how I will machine it, and then we see if it all gets clear
I will order a solid material with the diamterer 112mm and 1000mm long this week. The material is compared with SAE4340, but in sweden it's called SS2541.
Then I cut it down to 700mm for the main shaft and 2x 150mm pieces for the two outer lobs.
I will cut the middle part in the CNC-lathe, and then turn the two inner lobs in my manuel lathe.
So I will turn the excenters as well.
When I have about 1.0mm left on the diameter on the lobs I send it to harden, then I will grind(polish) it down to about +0.06mm.
Then I send it to nitrering (not sure about the word).
Then I will polish the last down to correct dimension.
The inner diameter of the lobs I will turn in my CNC-lathe aswell.
Also all milling of gears, holes and so on I will do myself.
Hopefuly my pics in future will tell you more
As always I try to do all machining, designing and welding myself.
I work in a workshop that manufacture water turbins. There I work with two CNC-mills, one small Matsuura with 700x400mm table, and one big Kiheung 4+2axles with 3000x1200x2000mm movement. I mill often 3D-blades like those in a propeller and so on... Much time in the CAD/CAM.
Regards
Tegheim
Old 03-21-10, 04:04 PM
tegheim's Avatar
Thanks! No I'm not an automotive engineer, just a hobby-engineer
Quick Reply: Tegheim - Home made 4 Rotor Wolvo project
