Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
na rear end strength
Old Mar 16, 2010 | 07:22 AM
truebluegallo's Avatar
will a gxl lsd rear end handle around 225 whp? with a good dif mount?
Old Mar 16, 2010 | 08:12 AM
Black91n/a's Avatar
It depends very much on the use, drag launches on slicks is a lot different than driving it gingerly to the store.
Old Mar 16, 2010 | 08:20 AM
drifting.
Old Mar 16, 2010 | 03:51 PM
lonetlan's Avatar
Too Many Questions
pinion snubber... I slide around on my 181,xxx diff with a pinion snubber(bump stop) installed. It works. But plan to change pumpkins. You will in the future.
Old Mar 16, 2010 | 04:48 PM
peejay's Avatar
Old [Sch|F]ool
They last a hell of a lot longer than the transmissions and driveshafts do, that's for sure.
Gear ratio plays a huge role. The lower the gear the weaker the gearset and the larger the forces it places on the carrier. One of my friends broke a 4.78 gearset with a stock port 6-port.
Old Mar 16, 2010 | 07:39 PM
forgot to se with pinion snubber also but 225 whp
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
