Idle problems
Old Mar 13, 2010 | 10:40 PM
valleyroger's Avatar
Idle problems
My 87 GXL won't idle when it's cold it will just stall out, once it's worm it idles ok.
But once it is worm if I try to hold the idle below 2000rpm it surges up and down between 2 and 1000 rmp? it won't surge at higher rmp.
Old Mar 14, 2010 | 10:28 AM
Aaron Cake's Avatar
Engine, Not Motor
Fix any vacuum leaks and adjust the TPS.
Old Apr 26, 2012 | 05:45 PM
oh9580's Avatar
My 94fd hsa same problem. when it's cold idle is hight over 2000rpm and sometime up and down between 1500 and 2000 rmp, but it's worm it idles ok.
Old Apr 30, 2012 | 05:30 AM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by rx-7PRIDE
......if it is too cold out it will not stay running as a rotary motor shouldnt be driven in real cold weather as they run a lot hottor than regular motors so the extreme cold can crack and break them pretty quick especially on start up and cool down
Please stop posting nonsense like this. And the rotary engine is isn't 2-cycle as you said in yet another silly post.
Old Apr 30, 2012 | 10:38 AM
Gringo Grande's Avatar
1.5 Goodfella's Tall
rx-7pride - I try and take it easy on the noobs however the only person opening their mouth around here and not knowing what they are talking about is you.
While the amount of time someone is a member of forum isn't always indicative of knowledge, SgtBlue is a rather knowledgeable member who in this instance certainly knows more than you...and has the cars to back it up.
So let's look at specific areas where you are wrong...
Cold Start Assist: It is 3k, not 2k as you stated.
RX7 Idle:
FD 750-800 with AC on 1000
FC: Idle once again is around 750
FB: I'm guessing...you got it...750.
Rotary engines run great in cold weather...BECAUSE THE AIR IS COOLER! Amazing, right? People have used rotary engines in everything from snowmobiles to airplanes You know it's cold when it snows...right? OMG how could a rotary snowmobile run in teh snow? Mind = Blown!
Seriously...your ego and poor attitude are making you look like a dick and the "information" you are spouting off is wrong and may mislead other new members who don't know that you know nothing.
I'm sure you'll have some witty response as you sound like you are about 18 (and your spelling and grammar resemble that of a 6th grade Middle School Dropout). Instead of being mad, you might actually want to spend time reading about the cars you claim to know about so your next contribution has a better chance of being correct...and work on your attitude as well...currently it isn't going to get you far around these parts.
Old Apr 30, 2012 | 07:26 PM
RotaryEvolution's Avatar
Sharp Claws
y'all are dumb, rotaries run on air. they are magical!
Old May 1, 2012 | 06:44 PM
rx-7PRIDE's Avatar
RX7 Idle:
jeez you can really tell when someone is an ignorant arrogant u.s ***** well bud how about you bring your rotory motor up here to canada in a minus 40 below 0 winter and tell me ur rotary even turns on rather than stay running, and im sorry i dont spend my whole day on a computer and making sure i type words proper for slow minded ppl as ur self to follow but i said it before ill say it again ive worked on my own cars my whole life and my rotary motor runs perfect and will continue to with me behind the wrench so say what you want bout my advice and the ppl who have used it and know it works will continue to follow my advice and you can follow who evers advice you please. Good luck with your own car
Old May 1, 2012 | 08:19 PM
Sharp Claws
except for the part about them cracking in the cold...
Old May 1, 2012 | 10:21 PM
gracer7-rx7's Avatar
needs more track time
rx-7PRIDE - you just earned yourself a 7 day suspension from the forum for your behavior. We do not tolerate insults and inflammatory behavior on this forum.
Read the rules of this forum and follow them or find yourself banned.
https://www.rx7club.com/announcement.php?f=256&a=185
Old May 1, 2012 | 11:22 PM
RotaryRocket88's Avatar
Top Down, Boost Up
In this thread: How not to introduce yourself to the forum.
Old May 3, 2012 | 10:06 AM
Aaron Cake's Avatar
Engine, Not Motor
Funny, all my rotarys have always started up cleanly and ran well in -40C weather. I drove a carbureted 12A for 2 years as a winter beater. Pull choke, crank, release choke. Purred like a kitten.
Perhaps it is your rotarys that don't run well in the cold? And perhaps it is somewhat related to the kind of advice you give?
Now I may be being a bit hard on you, but this is the new user technical forum and to spout obvious information will just confuse the new users. And lead them to take improper action, spend money, or generally be misinformed. This helps no one. In this forum, you must be careful what you say and you must know what you're talking about to help.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
