Power FC What cells I need to change when running RICH @ idle?
Hey I did a search nothing really seems to match what I am looking for. Anyway I copied a bunch of a forum member (arghx) post and still can't find what I need. Anyway car runs very rich at after it's warmup my aem wideband shows 12.6, and there is allot of fumes smell and sometimes a lingering hint of blueish smoke everything shows signs that it's burning very rich. I Yes i put new plugs only got 5 miles and when removed then the trailing are wet and black, Leading are black but dry, I did check for spark all coils are function and fianlly I put new taylor wires on. Also I still have my air pump and acv both system that are working properly Anyway I have on other post where u can lean out certain cells but those mention when crusing, I just want to lean it out for idle.
Thanks
Khris
Thanks
Khris
down load the commander manual from apexi website if you haven't all ready.
http://www.apexi-usa.com/content/pdf6759.pdf
Look at pg 17, and follow. It will show you what cells your running in at idle.
Go up in #'s to lean out. don't lean out your car to a majic #, but to where the car runs best, every car is diff.
Hey thanks, it appears that only p1 to p5 and n1 to n3 is only use at idle, I check my air/fuel setting and they all showing 214 for all of those see, if I go higher that would mean it will it get much richer, according to another post by aghx he mention to reduce it and I think gonna try both ways to see if anything changes.
Khris
Khris
Khris
Khris
Well I try those #'s & the car run like ****, right now i got them set at 100 from P1 to P5 and N1 to N5 and I got it to be between 12:9 to 13.6 btw when u reintialized the ecu does it change tune maps also or just basic stuff?
Khris
Khris
Trending Topics
My car was having the same problem.. It ended up being because there wasnt enough resistance going to the injectors.. So I had a honda resistor box wired in.. Before my tuner could change the tune, but it wasnt getting any real results.. The injectors were getting too much juice.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
rx8volks
Canadian Forum
Aug 13, 2015 04:55 AM
