need some help engine
Old Mar 12, 2010 | 08:36 PM
nishie123's Avatar
Hey all im looking to get a Rx-7 a late 80's and im wondering what kind of engines you can swap with. also im wondering if a 1.6l 1990 mx-5 engine would work in a rx-7. just looking to see if someone can list me some engines that will work, before i go off and make a purchase.
Old Mar 12, 2010 | 11:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Just about any engine will fit in an RX-7's bay. Is there a reason you think the stock rotary won't work?
Old Mar 13, 2010 | 08:06 AM
nishie123's Avatar
im looking for a project rx-7 that's some what cheep i found one for 600$ and it doesn't start the guy said so i was planning on getting it and swaping the engine right away even though that may not be the problem with the car. and i was thinking a 1.6l 90 miata engine and was just wondering if someone has done it ?
Old Mar 13, 2010 | 09:33 AM
88rx7gxlturbo's Avatar
If your going to go through the hassle of swapping in a new motor that wasn't designed for the car you should do something worthwhile that won't cost you a ton of money to make power. Drop a v8 in or put a stock engine back in. After all the hassle and cost of putting the miata engine in you are going to have less power than a stock n/a and have spent more time and money than it's worth. You could do a turbo swap for less than you could probably swap the miata in for.
Old Mar 13, 2010 | 10:46 AM
Aaron Cake's Avatar
Engine, Not Motor
Honestly if you have to ask, have you ever been involved in this kind of project before?
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
