New Dyno Numbers... 361.5whp 309ft-lbs
Old Mar 12, 2010 | 04:38 PM
FC3Sdrift's Avatar
Displacement Replacement
Im happy as hell with the numbers 361.5whp 309ft-lbs
i need a stand alone to switch my staging points earlier, i ended up having to just start my runs from 3500rpm
my primaries cant handle it
mods list
S4 TII
S5 TII jdm engine and electronics
Garret hybrid a/r .60 cold side, S5 hotside 16-17psi
Knightsport chipped ecu
apexi afc neo
AEM uego WBo2
6 x 550cc injectors
os giken twin disk clutch and flywheel
2.5" DP and 3" cat back
oldschool greddy fmic
mangled apexi intake
i need to rescan this so you can see it
http://www.youtube.com/watch?v=D_7rmdpz9ww
Old Mar 12, 2010 | 05:19 PM
sharingan 19's Avatar
Rotary Revolutionary
Nice!
I wonder what the maps on that ECU look like....
Old Mar 12, 2010 | 06:30 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
thats a awesome figure for a hybrid.
Did you know what kind of setting were in the knightsport?
Old Mar 12, 2010 | 06:40 PM
Nick_d_TII's Avatar
Nice! Swap in some 680 primaries and you should be set. Good job!
Old Mar 13, 2010 | 01:21 PM
junito1's Avatar
F**K THE SYSTEM!!
This is as simple as it gets...? Great numbers!!
Old Mar 15, 2010 | 06:10 AM
Demonsniper1's Avatar
The cross-eyed kid
So how many people have called you, since you left your number on the dyno chart and everything?
Old Mar 15, 2010 | 07:37 AM
FC3Sdrift's Avatar
only your mom hahahaha j/k
Old Mar 15, 2010 | 09:12 AM
The cross-eyed kid
Well next time she calls tell her I said Hi and I want a sammich.
Old Mar 21, 2010 | 08:14 PM
KhanArtisT's Avatar
Former FC enthusiast
Those have to be record setting numbers for a stock ECU/SAFC setup. What kind of AFRs was it pulling?
Old Mar 22, 2010 | 01:21 PM
funkjaw's Avatar
Beautiful numbers man.
Old Mar 22, 2010 | 01:29 PM
Pretty sure that ECU isn't mapped for 680 primaries... How much adjustment does the SAFC give you?
Old Mar 24, 2010 | 09:36 PM
FC3Sdrift's Avatar
50% +\- at 16 rpm points
afr are around 11.3-11.5
with only a 2.5" DP, i made a 3" last weekend, alot peppier around town....its fast WOT
I think J-rat made 400whp with a bnr stage 4 and safc and ecu but i think his motor was ported
Old Mar 24, 2010 | 10:26 PM
FC3Sdrift's Avatar
all i could find from jrat was with a t 61 turbo makin 400whp on stock ports?
Old Mar 27, 2010 | 11:46 AM
alemmons's Avatar
89 GXL Turbo
Veteran: Marine Corp
Very curious what turbo that is. You mentioned hybrid, is this the same as a BNR? If so what stage. I haven't seen many numbers like this with the BNRs so I would like to know more about the turbo. Nice numbers, I want something like that.
Old Mar 29, 2010 | 11:02 PM
J-Rat's Avatar
Alcohol Fueled!
Something like that... I cant remember.
Old Apr 11, 2010 | 01:54 PM
FC3Sdrift's Avatar
I rescanned the dyno sheet so you can actually see it lol the power comes on late because i did my pull from 3500rpm, but look at that torque curve, you can see where i lite the rocket hahaha
Old Apr 17, 2010 | 02:57 PM
evoentertainment's Avatar
call me noob, but how come youre running such small injectors @ such high boost? isnt that dangerous?
ive recently purchased my first 7, ive done some mods to it, rb 2.5 to back, a bnr stage 2 turbo w/ 550/720 running on a rtek 1.7. im boosting around 5.5-6 right now, ive always wanted to up my boost. with that said, I was planning to up my secondaries, install a boost controller, and install a safc neo to control fuel. does taht sound right with you guys?
once again im sorry for be a newb.
Old Apr 18, 2010 | 02:33 AM
FC3Sdrift's Avatar
i basically have 1100cc secondary injectors 4 x 550cc , but the way extra fuel rail is on there , it doesnt have a return line so they probably flow more with the extra pressure, thats how it came worked for over 3 years
i have a AEM wb02 my afr were around mid 11's , im still pulling 25% fuel at WOT
Old Apr 20, 2010 | 08:21 AM
Frostycrowd's Avatar
no return line, really?
Old Apr 24, 2010 | 11:31 PM
RXnos1200's Avatar
1200 gone......but......
nice pull.....
Old Apr 28, 2010 | 04:27 PM
abrobst's Avatar
nice numbers!
Old May 2, 2010 | 09:30 AM
Spirit-RE's Avatar
Wow, cost efficient and great numbers. Nice!
Old May 3, 2010 | 07:02 PM
arghx's Avatar
rotorhead
That knightsports ECU must have less aggressive timing at high loads compared to stock. That's why it's working out.
Old May 5, 2010 | 04:48 PM
sen2two's Avatar
Rx2 > FD
^ most likely. Cause i'm pretty sure when you take away fuel with any of the SAFC's it adds timing... Cool for NA cars, but very dangerous for turbo cars.
Put some water, meth, or a mix on there for safety...
Oh and would you happen to know the size on the compressor blades? Not the AR or the trim. But the actual size of the inducer and exducer?
Old May 6, 2010 | 11:40 AM
FC3Sdrift's Avatar
KS chip is mapped for higher boost, the stock ecu stops retarding the timing at a certain psi, i know they set the Rtek up to retard the timing 1 deg per psi above 9psi i think?
i haven't ever needed to take the turbo off so i've never got a chance to measure it all, im curious about it too. I have a RA basic rebuild kit sitting in my closet waiting to freshen my motor up sometime this summer. once i rebuild and streetport the motor im definitely going to get all the proper specs on the turbo
