Canadian Forum Canadian users, post event and club info here.
Went to the Dyno today. 361.5whp 309ft-lbs
Old Mar 12, 2010 | 04:32 PM
FC3Sdrift's Avatar
Displacement Replacement
Hey I'll post this here for everyone to see , Im happy as hell with the numbers 361.5whp 309ft-lbs
i need a stand alone to switch my staging points earlier, i ended up having to just start my runs from 3500rpm
my primaries cant handle it
mods list
S4 TII
S5 TII jdm engine and electronics
Garret hybrid a/r .60 cold side, S5 hotside 16-17psi
Knightsport chipped ecu
apexi afc neo
AEM uego WBo2
6 x 550cc injectors
os giken twin disk clutch and flywheel
2.5" DP and 3" cat back
oldschool greddy fmic
mangled apexi intake
i need to rescan this so you can see it
http://www.youtube.com/watch?v=D_7rmdpz9ww
Old Mar 12, 2010 | 05:40 PM
JDK's Avatar
JDK
Nice....must be a fun car, Dynojet?
Old Mar 12, 2010 | 06:22 PM
Bwek's Avatar
High Comp Booster
Nice job man
would that garret .60 cold side be the same as the 60-1 Hifi?
Old Mar 12, 2010 | 06:33 PM
thewird's Avatar
Nice numbers for a stock turbo, what's the peak duty cycle?
thewird
Old Mar 12, 2010 | 09:15 PM
FC3Sdrift's Avatar
17psi is probably about the max safely
it'd be like the bnr's , the only thing stock is the exhaust housing,its a garrett turbo jammed in the s5 exhaust housing, it has a different center section, but ive never taken the turbo off the turbo to measure the wheels. but its instant spool
the adjustable wg actuator is what makes it work so well
im building it up for time attack so meybe i'll see you guys in shannonville this season
Old Mar 13, 2010 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Looks like CTI has upgraded their dyno software. It's a Dynocom unit...
Is the eddy brake working at this point?
Good numbers, by the way.
Old Mar 13, 2010 | 04:33 PM
FC3Sdrift's Avatar
yeah the brake was working fine, it didnt tell me what rpm i was making my peak power at though, maybe i just had to ask so he'd switch it, it did last time so i just figured it would have this time
Old Mar 13, 2010 | 05:18 PM
Efini.7's Avatar
said your average hp is 270 i n the video ?
Old Mar 13, 2010 | 07:25 PM
FC3Sdrift's Avatar
yeah AVERAGE not MAXIMUM
from 3500-7000 I AVERAGE 270whp and 260ft-lbs
Old Mar 13, 2010 | 08:04 PM
IAN's Avatar
IAN
Rotary Reborn!
Thats pretty good. All you have is a knightsport ecu and a fuel controller? Mint. So you are turning on the other two injectors via the neo fuel controller?
Old Mar 13, 2010 | 10:43 PM
FC3Sdrift's Avatar
no they are just tapped into the stock secondaries, i just pull fuel from up top
Old Mar 14, 2010 | 08:36 PM
Hybrid G's Avatar
that is mint ... man thats some super number for the setup.... give me hope
Old Mar 14, 2010 | 11:36 PM
RX7(613)'s Avatar
Great numbers from a simple setup.
Old Mar 20, 2010 | 12:53 PM
rambo112200's Avatar
No Traction
nice set up good numbers from it!
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
RedBaronII
Sep 20, 2015 11:29 AM
