JDM 320mm race steering wheel install
Old Mar 11, 2010 | 05:56 PM
tangoshark's Avatar
sherevvs
OR JDM 320mm race steering wheel install
Hi guys,
I am thinking about purchasing this steering wheel, but I don't know too much about aftermarket steering wheels. I have a 88 FC convertible, and the steering wheel I am looking at is 6 bolts and made by JDM. the link is here
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
1) It seems pretty cheap so do you guys have any suggestions on how good this type of steering wheels are?
2) will installing aftermarket steering wheel mess up the turn signal and such?
3) is it safe to install it by myself (not much experience on this) ? or just find a tuning shop to do it for me?
thanks a lot
David
Old Mar 11, 2010 | 07:00 PM
hioctane-dtc's Avatar
I have an eBay steering wheel right now, it's 350mm because the 320mm is too small and requires fair bit of force to turn even with power steering.
1) Most of the steering wheels sold on eBay are very similar; quality is only decent enough to not make you upset about it, but it's not as good as it seems in the pictures. It's good to have in the beginning if you have low budget and would like to reduce the OEM 370mm steering wheel.
2) Yup, at least I would say so for the eBay ones. I tried two different eBay steering wheel on my current FC and a celica I used to drive before.
3) It safe to install by yourself, I believe there are installation guides on the forum you can search for. What you need is screwdrivers to take off the steering wheel colum, bolt wrench to take off the nut that's holding the steering wheel together. Most suggest using a steering-wheel wrench so that you won't bump your face when pulling off the OEM steering wheel, it's optional.
Old Mar 11, 2010 | 11:27 PM
tangoshark's Avatar
sherevvs
thank you for the reply hi octane!
Old Mar 11, 2010 | 11:29 PM
tangoshark's Avatar
sherevvs
Is there any site or brand of steering wheel you recommend, Hioctane or anyone else? thanks a lot
Old Mar 11, 2010 | 11:59 PM
rxtasy3's Avatar
i just got a grant gt model 724 and hub to fit an fb. haven't gotten to install it yet due to the rain. momo is another brand.
Old Mar 12, 2010 | 12:00 AM
The Spyder's Avatar
Never give up!
Hello David,
You will need an adapter hub. This allows the factory "spline" mount for the OEM steering wheel, to mount to most 6 bolt aftermarket wheels. I have removed a number of ebay wheels, just dont like the feel (just my personal opinion.) The ebay ones are cheaply made, fade + wear quickly. I would find a used Momo/Sparco wheel +hub.
You should pop down in to the "NW Section". If you need assistance installing this, give me a PM and you can swing by my shop. Its a 5 minute job with a little guidance and the right tools.
Old Mar 12, 2010 | 12:02 AM
What's your budget? name brand goes to couple hundred depending on what you get.
If you're concerned with budget, what you could do is source for a used steering wheel, and get a hub that fits through eBay (most aftermarket ones are 6 holes).
Brand name steering wheel most commonly selected/seen are: Nardi, Personal, Momo, Sparco, Grant, NRG.
Password JDM carries Nardi and Personal steering wheels only, no hubs for our 7's: www.passwordjdm.com
Most other name brand should be able to be sourced from the local authorized dealers, just ask around.
Old Mar 12, 2010 | 12:19 AM
tangoshark's Avatar
sherevvs
OR
hi spyder!
Thanks for the reply. You are the first one I met here who is also from Oregon. I just sent you a private message but I am newbie so don't know if I did it right.
Anyway, what's (Or where ) is the "NW section" you were talking about?
David
Old Mar 12, 2010 | 12:49 AM
rxtasy3's Avatar
David
go back to the main page and scroll down to the regional forum section.
Old Mar 12, 2010 | 10:46 AM
rxtasy3's Avatar
well it's not raining now so i got it installed.
Old Mar 16, 2010 | 04:56 PM
rtrhead's Avatar
looks good you still have the horn?
Old Mar 18, 2010 | 07:49 PM
tangoshark's Avatar
sherevvs
OR
whats a good steering wheel size?? which one do you guys think is more comfortable and handle better??
320mm or 350mm?? I think the factory 2nd gen is 370mm?
thanks for the input
David
Old Mar 19, 2010 | 12:25 AM
rxtasy3's Avatar
thanx. yeah the horn works. the wire just connects to the tab on the back side of the button.
