Microtech help wiring the speedo on my fd><>,,
Old Mar 10, 2010 | 09:36 PM
rx7convertion's Avatar
rx7fever
NJ help wiring the speedo on my fd><>,,
anybody knows how to wire the speedo to make it work????? since I installed the lt12s my speedo and tach stop working..................
thanks for any help..
Jesus
Old Mar 12, 2010 | 04:57 PM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
For the tach, you need the Dakota Digital box. There's lots of info on it here, a simple search will easily show you the directions for it.
As for the Speedo, I'm still trying to figure it out. People say wire it manually, but i'm not sure where/how.
Old Mar 14, 2010 | 04:00 PM
rx72c's Avatar
Top Answer: 1
Unless you have a 20b YOU DONT need anything to get the tach to work.
Old Mar 26, 2010 | 03:03 AM
paximus's Avatar
Oh, sorry, yeah, I guess i assumed with the 12s.
Old Apr 5, 2010 | 06:23 PM
danameisoj's Avatar
I love how people keep posting that theres plenty of info on here regarding how to get things to work..yet
i too had the question of how to get the tach to work on my fd.. its still remained unfound for 3 years...
i even just recently did more searching and found my post from 3 years ago and still yet to have a functioning tach
does anyone actually have the information?
instead of yelling to search it would be alot easier to post what wires have to go where . therefore actually creating a helpful forum.
Old Apr 11, 2010 | 04:05 PM
jm93rx7's Avatar
Committee Member #3
MI
I have an LTX8s on My FD and rx72c has a great write up on getting the tach, oil, water, and fuel guages to work. Thanks again .. Im also still trying to figure out the speedo.
Old Apr 11, 2010 | 04:50 PM
jiggaFlexxx's Avatar
Same here..... Still trying to figure out the speedo??
Old Apr 11, 2010 | 09:52 PM
BluRR's Avatar
when I had the plug and play harness on my car everything worked fine...
Old Apr 11, 2010 | 10:07 PM
jm93rx7's Avatar
Committee Member #3
the plug and play adaptor uses the stock FD engine harnes. The speedo runs through the stock FD engine harness.
Old Apr 12, 2010 | 08:15 AM
BluRR's Avatar
So why cant somebody trace out the lines and make sense of it? Because obviously it not required to pass thru the ecu to work
Old Aug 1, 2011 | 04:50 PM
snapcaseacilec's Avatar
Bottled at the source
any body got a link to help remedy this problem
thanks
Old Sep 23, 2011 | 03:00 PM
killahrx7's Avatar
dyno queen potentials
for speedo to work use part of original harness and ground a few wires, speedo will work
Old Sep 23, 2011 | 04:11 PM
jm93rx7's Avatar
Committee Member #3
this is what i was told to do.. Hope it helps..
Step one
get under the glove box side of the dash and find the big white connector X-14. Find the Yellow/red stripe and Yellow/white stripe wires on the DASH side on the connector. Cut them loose from the connector so you have about 4" of wire to work with.
Step two
run a length of wire from the Y/R wire on thru the firewall and down toward the transmission. Run a similar length from the Y/W wire.
Step three
On the manual trans, pass side is the speedo sensor. Take the connector off the small steel panel that holds it on the driver side. Look at the connector straight onward, note where the harness male connector snaps into the speedo connector. With the snap point on top ( connector release ) the wire to the left will connect to the Y/R and the wire to the right will connect to the Y/W wire. Cut the connector off and wire them up temporarily. Now your Speedo is wired directly to the harness going to the dash Speedometer.
Step four
take the car around the block. Does the Speedo work now ? If yes, solder the connections, tape them up and secure the wires. If no, reverse the wires at the transmission, repeat. It should work, if not then something is wrong with the Speedometer or the dash harness
rgordon1979
40
Mar 15, 2022 12:04 PM
DocHoliday89
Oct 12, 2015 07:42 PM
