Plugs, wires and igniters
Old Mar 7, 2010 | 10:15 AM
klatoo's Avatar
I bought a 88 vert as a drivable project car and have replaced the plugs and now I see I need to replace the plug wires as well.
Any suggestions or advice on how not to do it?
Old Mar 7, 2010 | 05:46 PM
misterstyx69's Avatar
Retired Moderator, RIP
BUR7EQ's on the bottom(leading plugs) and BUR9EQ NGK plugs on the top(trailing Plugs)
if in doubt about wires just change them one at a time.you will be fine
If not,Here,Read My reply in this Thread.; https://www.rx7club.com/showthread.p...ht=spark+plugs
Old Mar 7, 2010 | 06:58 PM
CS13B's Avatar
From the Roots Up!
The OEM wires from Mazda are NGK and come with T1, T2, L1, L2 in raised lettering on the ends of the wire so you cant mix them up. They are blue and red and look pretty good in the engine bay too lol
Old Mar 7, 2010 | 07:47 PM
AcidShock's Avatar
Eet fase
Just take one plug wire off at a time and replace it. Simplest and easiest way to not mess it up.
Old Mar 7, 2010 | 09:02 PM
datz's Avatar
GNARKILL
my 1990 gxl has all blue wires with the t1, t2, ect marks on the wires.
the boot connectors are black for leading and blue for trailing.
Old Mar 7, 2010 | 09:23 PM
CS13B's Avatar
From the Roots Up!
When I bought the wires for my 88 vert last summer both pairs were blue wires, one pair had red boots, one pair had blue boots. Maybe they changed them? I don't think they would be any different between US and CAN. It's more likely they change from s4 to s5 though.
Old Mar 8, 2010 | 10:53 AM
klatoo's Avatar
Thanks all
Old Mar 8, 2010 | 11:22 AM
LikeThunda's Avatar
Lol
just yankthem out.and put them back in ..the right order
Old Aug 3, 2010 | 05:46 PM
klatoo's Avatar
NC What do you know
It works if you put them in correctly and don't use cheap wires...
All is well, I bought a set of accel wires and replaced all 4 plugs, what do you know the damn thing fired right up
Thanks for all the advice - even the sarcasm...
The1Sun
Mar 18, 2018 11:08 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
