Rotary Drag Racing The place to post your racing stories and info
Line locks / roll controls
Old Mar 6, 2010 | 02:37 PM
IanS's Avatar
Ricer
What do you have and how are they installed? Also I believe I need 2 of them for my FB as there are 2 lines coming out of master to each front brake (1 line to left, 1 line to right).
I am assuming they are installed in between master and brake (basically).
Thanks
-Ian
Old Mar 8, 2010 | 07:45 PM
IanS's Avatar
Ricer
OK, how about this - Is there any specific brands you feel I should stay away from?
Old Mar 10, 2010 | 10:03 PM
Busted7's Avatar
Will work for horsepower
You only want one for both front breaks.
Old Mar 13, 2010 | 12:01 PM
ALNY93R1's Avatar
I use the Hurst Roll Control unit.
Old Mar 15, 2010 | 10:16 PM
Dan_s_young's Avatar
Turbo widebody FB
Hurst as well here. The FB only has one brake line going to the rear, I redid all the lines on my car. The lineloc goes in the line to the rear brakes to block off pressure, hardest part is finding the right fittings to go from the strange mazda brake 3/16 brake line fittings to the 1/8th fittings on the lineloc.
Not the greatest picture of it, but it is on the firewall.
Old Mar 17, 2010 | 08:40 PM
Busted7's Avatar
The line lock goes to the front brakes and holds pressure so the back brakes dont drag on the burn out!
Old Mar 17, 2010 | 09:46 PM
Viking War Hammer's Avatar
*** Bless The USA
Charlie.... I'll have something for ya this weekend
Old Mar 18, 2010 | 09:14 PM
Busted7's Avatar
Let me guess, no thats not it!
Get in touch!
Old Mar 18, 2010 | 10:16 PM
*** Bless The USA
scratch that! I'll have somethin for ya tommorow !
will post pics!
Old Sep 20, 2011 | 12:10 AM
sk8world's Avatar
Chasing numbers
Bump for Bobby!
Old Sep 20, 2011 | 04:57 PM
vincentrx7's Avatar
Thanks Mike.
Old Sep 20, 2011 | 08:27 PM
jm93rx7's Avatar
Committee Member #3
I bought the B&M and will be installing it here in the near future
Old Sep 21, 2011 | 07:22 PM
vincentrx7's Avatar
I'm buying the B&M also. Hurry up and install and get some pics up:-)
Old Sep 21, 2011 | 08:13 PM
vincentrx7's Avatar
Old Sep 21, 2011 | 09:02 PM
rXc3|\|tR1c's Avatar
Auto Pilot
This is how I did mine (FC), I assume it would be similar for you guys in the States
I took the line from the bottom outlet and blocked the outlet on the side (which you can see in the second pic) and then just bent the existing lines slightly into the t-piece. I think mines a Morosso item, no complaints from me. And yes, as has been mentioned the Mazda fittings are all metric however the t-piece and locker are imperial. If your having a hard time finding them I'd just cruise down the the local wreckers and get some off any Mazda as they should all be the same size.
Tone
Old Dec 11, 2011 | 10:36 PM
jm93rx7's Avatar
Committee Member #3
Got around to doing mine last weekend.. I already have an ABS delete kit on my FD so it was pretty straight forward.
Th0m4s
Feb 26, 2019 02:04 AM
diabolical1
30
Jan 30, 2016 05:50 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
