new carb and fuel pump, psi probs
Old Mar 5, 2010 | 10:31 PM
4pistonkiller's Avatar
rx7 nOOb
OR new carb and fuel pump, psi probs
so i just finished installing a holley red fuel pump and a carter 500 cfm carb with my new racing beat holley/carter intake manifold, and we got the car to fire and run, but the fuel pressure is all over the place, it varies randomly from 3-6psi, i do have a regulator installed, but am not sure what the problem is. this is on a 12a. my friends car has the identical setup, except the carb is a 600 and the motor is a 13b. im really puzzled as to what the problem is, maybe the fuel pump itself needs a chassis ground ??? i dont know, but would really appreciate some help.
Old Mar 9, 2010 | 12:14 PM
LikeThunda's Avatar
Lol
hmmmm.. checking your Grounds would be a Good start..
Old Mar 9, 2010 | 12:29 PM
polito Racing's Avatar
so you got pistons oh wow
is your fuel pump above or below the fuel tank?
Old Mar 10, 2010 | 03:26 PM
rx7 nOOb
OR
the pump sits right about level with the tank, and i finally got the carb rebuilt, and its running alot better, especially since i did the heat range 7 and heat range 9 plus instead of just 4 heat range 8 plugs.
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
Skeese
65
Mar 28, 2017 03:30 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
