With my Mods do I need a boost controler or upgraded BOV?
Old Jun 17, 2002 | 06:21 PM
Rpeck's Avatar
What R U thinking self?
thx.
I am not quite sure what these two items acomplish
Old Jun 17, 2002 | 06:26 PM
MtnRacer's Avatar
infini guru
If you're making over 12 psi, get an aftermarket BOV.
Steve
Old Jun 17, 2002 | 06:28 PM
NZConvertible's Avatar
I'm a boost creep...
A boost controller is used to raise max boost. An electronic one also increases the speed at which boost rises, so even if you leave your boost level the same, you’ll see an improvement in mid-range torque because max boost is reached earlier.
Your stock BOV is fine unless you’re running over about 13psi boost or you want to make some noise.
Old Jun 17, 2002 | 06:29 PM
Ranzo's Avatar
If you want to go faster then you need a boost controller. This will allow you to change when the wastegate opens thereby giving you higher output from the turbo.
If you want to protect that turbo from compressor surge then you need a BOV
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
