White Powder in Exhaust
Old Mar 4, 2010 | 10:09 AM
ffilemyr's Avatar
FFilemyr
MD White Powder in Exhaust
I have replaced stock exhaust manifold with a RB header when i pulled the manifold off there was a white power all the way down to the C converter. it does not rub off easy has no smell.. looks like a power coating... Did not have any problems with the motor before i started working on it any ideas??? its not a big deal just want to make sure there are not any problems!!
Old Mar 4, 2010 | 11:26 AM
RotaryRocket88's Avatar
Top Down, Boost Up
It is a byproduct of the combustion process. Nothing out of the ordinary.
Old Mar 4, 2010 | 01:23 PM
LikeThunda's Avatar
Lol
u should be Fine.
Old Mar 4, 2010 | 04:14 PM
ffilemyr's Avatar
FFilemyr
Thanks some one said i might be running lean. I just ordered a fuel/air monitor so i guess i will know when i put that in
Old Mar 4, 2010 | 04:42 PM
Top Down, Boost Up
Light colored deposits are from "lean" operation. Whenever you're cruising, the ECU will be in closed loop operation, which keeps the mixture right around 14.7 (Stoich.). As I said before, it's normal.
Also, if the gauge you ordered is a narrow band (the $50 kind that uses your stock O2 sensor), it won't tell you much. Only a wideband sensor/gauge can tell you exactly.
Old Mar 4, 2010 | 05:30 PM
ffilemyr's Avatar
FFilemyr
Yes i ordered a nice one AME wide band. i try not to go cheap when ever i can
http://www.jegs.com/p/AEM/AEM-6-in-1...61747/10002/-1
Old Mar 4, 2010 | 05:34 PM
LikeThunda's Avatar
Lol
^^^ yeee wide bands are nice..
tiger18
Sep 3, 2015 08:27 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
