FMIC for FD3s
Old Mar 3, 2010 | 06:08 PM
paul1985's Avatar
CA FMIC for FD3s
I have a front mount i have recently installed as well as a aluminum 3 core radiator. the install went good but i hooked back up my A/C system since i live in California. the car is only going to be a few times a month driver and thats it. I dont have much room in between the A/C condensor and the radiator. Its a Greddy kit so the radiator and the condensor are both vertical. would any of you guys ditch the A/C or keep it for the extra space and flow to the radiator.
Old Mar 3, 2010 | 08:35 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Do you really want to not have AC? I doubt you are going to see much benefit.
Old Mar 3, 2010 | 09:07 PM
dgeesaman's Avatar
If it's that warm I'd be more concerned about the radiator getting enough flow in traffic on a hot day. Leaving the AC in makes that a little worse. FMICs are not as robust in street and track duty compared to stock mounts or v-mounts, which is why they're usually used only in drag setups.
Old Mar 4, 2010 | 03:26 AM
juicyjosh's Avatar
Seismic Disturbance
Agreed. I have the GReddy V-Spec FMIC, and I removed all the a/c parts under the hood. This made the front of my car 20 lbs lighter with more of the actual engine exposed to ambient air. I also got another 1 hp from not having to drive the a/c motor
Since my Koyo sits behind the intercooler, I installed a manual fan switch. I also have a vented hood.
Old Mar 4, 2010 | 01:15 PM
datz's Avatar
GNARKILL
hhhmmm . . . . A/C or 1 hp.
its a tough decision.
Old Mar 4, 2010 | 01:27 PM
LikeThunda's Avatar
Lol
^^^ lol.... i never really use A/C. plus it went bad. lol...so i got rid of it
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
cto_2
19
May 8, 2018 08:15 AM
