turn/hazard
Old Mar 2, 2010 | 06:49 PM
datz's Avatar
GNARKILL
AZ turn/hazard
my turn signals dont work!, ive checked the fuses, cleaned the switches and cpu with radioshack electric cleaner, checked the bulbs.
when i flip the switch it clicks under the dash like it should.
with it my hazards dont work, when i hit that button it clicks under dash like it should.
Old Mar 2, 2010 | 08:38 PM
mar3's Avatar
Administrator
Releasing thread so that the 2ndgen electrical guru's can help this member out...don't get me to lying, I'm a 1stgen cheapskate!
Mario III
Old Mar 2, 2010 | 08:42 PM
J-Rat's Avatar
Alcohol Fueled!
More then likely the sockets are corroded.. Have you removed and inspected the bulbs?
Old Mar 2, 2010 | 09:01 PM
datz's Avatar
GNARKILL
yup, bulbs and sockets are fine. (almost new looking sockets!)
the passenger front turn housing is broken apart, but with that one out the others should work right, right?
Last edited by mar3; Mar 3, 2010 at 04:26 PM. Reason: Merged back-to-back posts...
Old Mar 2, 2010 | 11:35 PM
infinite7z's Avatar
Noob Member
yeah the others should still work. correct me if im wrong but if you turn on the lights, the turn signals light up too. if im right and yours light up then it has to be somewhere between the turn signal switch/ hazards to the bulbs. again im not 100% sure. hope i helped
Old Mar 3, 2010 | 01:36 AM
datz's Avatar
GNARKILL
is there any relays, cause the fsm dont mention any?
Old Mar 5, 2010 | 02:15 AM
datz's Avatar
GNARKILL
boy this sites search engine suks major donkey dik but but with google i found answers.
Old Mar 5, 2010 | 01:18 PM
Zethreal's Avatar
What am I doing?
As you found the answer, would you be able to post it here for other people to reference in the future?
Old Mar 5, 2010 | 02:39 PM
datz's Avatar
GNARKILL
AZ
https://www.rx7club.com/showthread.p...=turn%2Fhazard
the answer was a combo of staring at the wiring diagram for hours these threads and alot of thinking. good luck!
Steves13b
Mar 9, 2011 01:57 AM
ximi
Jun 19, 2002 06:21 PM
