ABS noise
Old Feb 28, 2010 | 07:22 PM
infernal's Avatar
ABS noise
Hello all!
I own a 2nd gen RX7 and I've noticed that when I start the engine and start to move for the first time after the startup, a brief noise is heard most probably from the ABS unit. Just like a motor is operating inside. The same noise is also heard when I pull the handbrake hard while moving.
Is this normal? Why is it heard even if I do not apply the brakes?
Thanx a lot!
Marios
Old Mar 1, 2010 | 10:13 AM
infernal's Avatar
*add: The ABS works as it should under braking.
Thanx again!
Aramir
Oct 18, 2015 02:39 AM
RuffRx7
Oct 1, 2015 03:08 AM
