Sponsored by: CARiD
13b side seal clearencing
Old Feb 27, 2010 | 09:22 PM
fidelity101's Avatar
Rallye RX7
Question 13b side seal clearencing
Okay I am getting ready to do some assembly and I have an excess amount of good used side seals when the motor was stock but now its undergone a streetport I wanted to know what I should clearance my side seal to corner seal clearance to.
stock application spec is .003"
so should I go tighter if I can? .001" .002" I doubt I should go loose but I wanted to know your opinions. First rebuild.
Old Feb 28, 2010 | 03:24 AM
urquhartglen's Avatar
unless its aftermarket seals (set to what they say) otherwise stay with factory clearance... if its running meth or lots of boost or race car running at very high rpm all the time would be the only time you should increase clearance
Old Feb 28, 2010 | 03:40 PM
Rallye RX7
its just gonna be a large/medium streetport, stock seals. non turbo, no meth or boost. but it will be driven at high rpm but the motor is an S5 so it could see 9000 rpm, but i doubt it will peak power at that.
Old Feb 28, 2010 | 04:01 PM
C. Ludwig's Avatar
www.lms-efi.com
NA you'll want to keep it tighter. Say .0015" - .002".
Old Feb 28, 2010 | 07:49 PM
Rallye RX7
thanks
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
