FC code 27 metering oil pump HELP PLEASE
Old Feb 27, 2010 | 01:29 AM
supak111's Avatar
Question FC code 27 metering oil pump HELP PLEASE
I need help figuring out where the metering oil pump is on a 93 rx7? Got the CEL on code 27. I didn't have this problem before but I just did a intercooler and piping install and after the install I get the code??? I also messed with some vacuum lines fixing them and all that, could any of this be related? Any help or suggestions will help since I'm totally new to rotary but i dont know a LOT about regular engines. Thanks everyone
oh PS I read that it could be the mop possible just getting stuck sometimes, is there anything I can do or maybe add to the oil to clean it up a bit like "seafoam", that stuff does wonders to regular engines???
Old Feb 27, 2010 | 01:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The OMP/MOP is on the front cover. When they fail, it's basically time for a new one. I've never heard of anyone fixing one. Unless the plug has come loose, you're probably not going to find an easy fix.
Old Feb 28, 2010 | 03:31 PM
supak111's Avatar
How hard it it to remove the omp while the engine is still in the car?
Old Mar 1, 2010 | 10:31 AM
Top Down, Boost Up
It's not the difficult. Download a copy of the 3rd gen FSM (links in the FAQ), and familiarize yourself with the engine bay. The pump bolts to the passenger-side of the front cover, and will have (brittle!) oil lines running up towards the intake manifold.
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rocker1337
16
Sep 6, 2015 11:28 PM
