Power FC :goodrebuild: APEXi Electronics - Power FC for a FC?
Old Feb 27, 2010 | 12:58 AM
Brah's Avatar
Drift Whore
So I recently got a project car a 1986 FC with a 87 JDM 13bt swap for $700
All of the electrics are shot or gone. It runs, sorta, like i test drove it after coaxing it to start after 45 minutes. I think it sat for about 6 months.
The guy who had it before me 'tried to tuck the wires so it looks supa clean so i culd enta Hellaflush IV, but i wen *** up small kine so i took most of um out li dat'
The ECU and Harness and everything are there, and but it is a disaster. And seeing as i have to run new wires to all the lights and everything else (i was going to go to a rocker switch pannel for everything just because ) I am considering throwing in an after-market engine management system. It would be helpful if this helped delete things like the MAF and stuff, but not really necessary.
Doing just a little bit of research i came across the APEXi Electronics - Power FC: http://thmotorsports.com/apexi_integ...15A04Z-03-1990
Seriously i cant argue with that price for what they claim it does, any other suggestions, tips, or ideas?
Looking around they were originally only for FDs but if i am understanding things correctly they have since made ones for FCs, that site that i linked says that that is FC compatible (specifically 1986 - 1992)
I am savvy enough to do some modifications, I was hoping there may have been some one who has used this product before that could lead me in the right direction. I don't mind ghetto rigging garage jobs (saab and volvo parts in my miata lol) but i also don't really like buying things blind.
Thanks for your help.
I will look into Banzai and post any findings.
Old Feb 27, 2010 | 05:45 AM
Banzai-Racing's Avatar
Rotary Specialists
This is the pressure sensor kit only.
There is no product that fits the 86-92, it is an error on Apexi's site and vendors that don't know any better continue the problem. The S4 and S5 harnesses are not even close to being compatible with each other. The S5 PFC that AP Engineering was putting together was a modified FD unit. It is incorrectly listed on Apexi's site as 86-92 http://www.apexi-usa.com/products/?id=5354 . It is listed as $1380.00 and does not come with the commander or the pressure sensor kit that you have listed above. You also need the FD intake aire temp sensor.
If you are looking to put a PFC in an S4 (or S5) our adapter kits are the best way to go about it.
Old Mar 7, 2010 | 04:45 PM
thewird's Avatar
I always wondered if the powerfc for the FC was direct plug in play with your harness or if you needed to change sensors. So I take you need the FD AIT sensor and a map sensor with a known calibration (assuming the FC one isn't known which it might be)?
thewird
Old Mar 9, 2010 | 12:07 AM
arghx's Avatar
rotorhead
thewird
I'm sure you could make the FC 2 bar sensor work if you did some testing to come up with a calibration value. But most people just go to a GM 3 bar. You need an IAT sensor with the FD calibration. I have used the Triumph sensor and the FD sensor.
All the other sensors are the same or very close electrically.
Old Mar 10, 2010 | 06:14 AM
Rotary Specialists
The AIT and MAP sensors need to be changed with both our adapter for the FD PFC and the AP PFC, this makes it no less plug and play. We even provide adapter harnesses for the sensors, making them PNP as well. The S5 pressure sensor could be calibrated to work, however the S4 is different electrically.
streetlegal?
Mar 17, 2022 02:46 PM
Skeese
65
Mar 28, 2017 03:30 PM
