mass air flow
Old Feb 16, 2010 | 09:02 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
OR mass air flow
i got my fmic done ................is it ok to have maf sideways ??:? what will be results ??also its only runnin 6 psi . now . :} 10mm
Old Feb 16, 2010 | 09:16 PM
hornbm's Avatar
FD > FB > FC
I recall reading that its not a good idea with the s4 ones. Might be less of an issue with the s5 ones, but looks like you got a s4. Not 100% on this tho.
Old Feb 16, 2010 | 09:28 PM
blwfly's Avatar
kiwi from downunder..
usally u want it flat so the door has no strain on its hinge and mounted so it dosn't vibrate.
Old Feb 16, 2010 | 09:59 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
its 1987 . s4 ,,,thx
Old Feb 16, 2010 | 11:28 PM
The Spyder's Avatar
Never give up!
Bruce, it needs to be sitting just like the factory position. 6psi can be caused by a number of things. Give me a txt if you need someone to look over it.
Old Feb 17, 2010 | 06:12 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
ok , got maf level ///// turned boost up , it went to 12 . blew all lines off . i dont think i need 12 . lol / holy **** .............. idles like **** . i took smog **** off,, 10mm
Old Feb 17, 2010 | 06:30 PM
hornbm's Avatar
FD > FB > FC
Put a dab of super glue on the inside of the vacuum lines and use some small zip ties and they wont blow off again.
Old Feb 17, 2010 | 10:00 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
inter cooler piping . is what blew off
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
