Rozuki Roturai build
Old 02-09-10, 08:03 AM
1972 Rx2/1988 Rx7 TurboII
Tsi_Xtreme's Avatar
Ok I'm going to try to write up a build for everyone. Seems there are rotary samurai's everywhere but no write ups. So I figured I'd write what I find with mine.
Now lets start the questions.
1) why would you want to do this?
A) Simple. It fits, can bounce off the rev limiter, and has almost triple the HP
2) how are you going to hook up 13b to the sammi transmission?
A) I'm not. the samurai has a divorced transfer case so you can use the rx7 tranny
3) Rotaries have no torque, why would you do this?
A) stock sammy engine has about 40-50 tq I think the 110 tq will be ok.
So I'm starting with a 88 Suzuki Samurai with 4wd. I'm going to keep the 4wd as this will be for off road use.
I've started by locating a good donor car. After seaching I was able to locate a guy that had a 88 FC waiting a v8 transplant. So I was able to get everything I needed
Engine
Trans
engine harness
ECM
Coils
radiator
oil cooler with lines
clutch master and slave
and alot of misc parts.
lucky for me I also got a spare and tranny as well.
Old 02-09-10, 09:13 AM
kiwi from downunder..
blwfly's Avatar
cool project ill be watching
Old 02-09-10, 06:34 PM
$ ain't everything, rite?
Bugeye RX's Avatar
Yeah what Fly said!
Old 02-09-10, 06:36 PM
p_rican's Avatar
nice keep us updated
Old 02-09-10, 08:24 PM
rotarysuzuki's Avatar
Nice, can't wait to see it done.
Old 02-09-10, 08:56 PM
EL BAMBINO RX3
BOOM's Avatar
must lift the front body about 3 inches for clearence of the oil pan &front diff I HAD A MAZUKI ABOUT 15 YEARS AGO 12a streetport ,webber bronze clutch had lots of fun draggin or muddin or on the beach lol
Old 02-25-10, 10:42 AM
Tsi_Xtreme's Avatar
Lifted!!! $30 bucks!
Old 03-27-10, 07:36 PM
Tsi_Xtreme's Avatar
Pulled the engine today. Don't think I need to get into detail on this. Pretty much un plugged all sensors and unbolted mounts and out she comes. I did do a test fit with the 13b first to see what we were looking at, then the engine with tranny. The engine should be pretty straight forward. I'm going to need to cut out the stock engine mounts and mock up some new ones but first the tranny. The tranny is going to need to be shorten and mounted first. There is really no way to get around this. I'm going to cut about 4" out of the shift linkage and see where that leads us. I'm also concerned on how to hook the tranny to the transfer case as there isn't much room. Tomorrow I'll be taking apart all the wiring and except the ones going to the cab and the lights. There is no engine wiring harness on this thing like with the rx7 so I'm going to have to get rid of the crap I don't need.
Old 03-27-10, 07:39 PM
Tsi_Xtreme's Avatar
I also painted it. Rattle can flat camo tan with black trim. Turned out really well, the wheels also had paint on them so I took it off to find chrome.
Old 03-27-10, 08:32 PM
Luis Rx3 Project
chino_rx3's Avatar
is looking good. keep it up ,
Old 04-04-10, 09:43 PM
I'm awesome!
IaMtHeRuThLeSs1's Avatar
Wow that looks great!
Old 04-08-10, 10:40 PM
datfast1's Avatar
Here one for you Rotary Samurai lover.
http://www.youtube.com/watch?v=TgMAFPe1W-Y
Old 04-09-10, 01:46 AM
Rx7 Wagon
Narfle's Avatar
awesome vid^
Old 04-09-10, 02:30 AM
datfast1's Avatar
Make sure to watch all of the clips. This Samurai kickass all the way to the finals. Enjoy!!!
Old 04-10-10, 02:44 PM
Tsi_Xtreme's Avatar
all wiring done as far as the sammi goes. Cut out what I didn't need and cleaned up the bay. I'm currently stripping this block so I can get rid of unwanted items. Might be going with a engine management system to control it, but my buddy ensures me its not necessary. I'm going to do some research first but for now going to fabbing egr plates and oil pump plate and ports.
Old 04-12-10, 09:12 PM
p_rican's Avatar
everything is looking good good job
Old 04-19-10, 12:50 AM
datfast1's Avatar
I miss my Suzuki Samurai. Yours will be sick when you get finish.
Old 04-19-10, 04:07 AM
WAS:12A's Avatar
Keep the updates coming!
I've always wanted to do one of these, so i'm watchin eagerly.
Cam...
Old 05-03-10, 01:35 PM
Tsi_Xtreme's Avatar
done some good work today! Cut out the engine mounts on the sammi. Found out I can't cut out the tranny mount. However, I CAN use the stock rx7 tranny mount. Just had to unbolt it and reverse it and worked perfect! just need to drill some holes and get some bolts. Had to cut out the tranny channel for the new shifter location but still worked out pretty good. Also had to modify the shifter linkage to shorten it.
Old 05-03-10, 08:18 PM
Autocrossed. I got CONED!
EricRyan's Avatar
Friggin' amazing! Keep up the good work!
Old 05-03-10, 11:14 PM
blwfly's Avatar
awsome
Old 07-12-10, 08:24 PM
durnzuki's Avatar
Definitly gonna watch this as I am doing the same thing with a 12a
Old 07-25-10, 07:55 PM
Tsi_Xtreme's Avatar
update... so I've taken some time off from this and have back tracked little. I did take the two driveshafts over to a local shop to have them mated. Its going to be a rx7 yoke-ujoint-sammi transfer case mount, should only be a few inches long total. Haven't mounted engine or tranny yet. After the shaft is finised I'm going to place it together and take careful measurements to make sure everything is lined up before mounts are welded in place. Also decided to ditch my original tranny mount set up. The first one was going to mount to the floor and seeing that its not the sturdiest thing in the world I figured out a different way to mount it to the frame but I have to get everything mounted up for I can do that one. Decided today to cut the factory door mounts so the doors can come off and on easily. I also found a grille guard today at the flea market for 8 bucks that is pretty heavy duty and will only take minor modification to make work.
Old 07-25-10, 09:59 PM
Noob Member
infinite7z's Avatar
haha this is awesome!! After I finish my jdm swap into my fc, I wanna drop a jdm s5 turbo 13b into a geo metro. convert it rwd. good luck and keep us updated
Old 07-28-10, 12:11 AM
OneSickRx3's Avatar
Suzuki 13b N/A 86-88 Non Turbo Set Up
My buddy is doing this swap on a non turbo, and we are stuck on the wiring of the ignition.
Do I need to connect the coil packs to the stock Samurais wiring harness and it's stock ignition wiring? Does anyone have a picture of this setup? Please let me know what you guys did to use the N/A setup and using a 13b stock ecu?
Thanks.
Quick Reply: Rozuki Roturai build
