Haltech E8 to FD stock ign wiring
Old Feb 6, 2010 | 01:59 PM
krayton's Avatar
Just wanted to double check my wiring. I have the correct wires on the ign module. Just wanna make sure they are connected to the right ign outputs on the haltech itself.
Can anyone chime in?
Old Feb 7, 2010 | 12:11 PM
C. Ludwig's Avatar
www.lms-efi.com
IGN 1 is leading, IGN 2 is T1, IGN 3 is T2. Setting is wastespark. Is that all you need?
Old Feb 7, 2010 | 02:17 PM
krayton's Avatar
pretty much, thanks. well somewhat on the same topic (well if u cant answer ill prob just do another topic)
but haltech sent me a crank sensor diagram for the FD with ign settings. theyre generally different then the ones posted here
but more questioning why they say 24teeth offset 5. i know u have to lock the timing and adjust, but why so different then the suggested 65, 11 posted here
Old Feb 7, 2010 | 05:50 PM
C. Ludwig's Avatar
www.lms-efi.com
The 65 and 11 you see so often is for the FC CAS. The FD requires different settings.
Old Feb 7, 2010 | 06:30 PM
krayton's Avatar
10 4. well back to the orginal post.
why does my e8 seem to be using ign1, 3, and 4. from what ive been reading its suppose to be 1,2,3. i wired it up that way with ign 2 not firing.
now finding with the multimeter that its 1,3, and 4. seems to match what a psport1000 does. (diagram wise)
Old Feb 7, 2010 | 06:46 PM
C. Ludwig's Avatar
www.lms-efi.com
Eh, you're right. It's 1 for leading, 3 for T1, and 4 for T2.
Old Feb 7, 2010 | 07:56 PM
krayton's Avatar
e8s must be the grey area. haltech sent me a diagram for wiring the ignitor and they also had it as ign 1,2 and 3.
Old Feb 7, 2010 | 09:13 PM
C. Ludwig's Avatar
www.lms-efi.com
If you look at the last few pages of the manual they have a setup guide for different applications. It's spelled out there.
Old Feb 8, 2010 | 07:46 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Care to post that diagram up? Doesnt make sense that they would send you an incorrect diagram.
The reason for the 1-3-4 output arrangement is cause thats how haltech did the E8/E11 hardware to work with the Wasted Spark (leading firing together) configuration.
Make sure that the diagram you haven isnt for an FC, not an FD, the FC's use the "toggle" option on the stock module hense, the different wiring and configuration in the software.
Old Feb 9, 2010 | 02:12 PM
krayton's Avatar
touche. i actually was looking for that earlier. flipping through a pdf is a bit different then a physical manual i guess.
claudio ill get that up. I was talking to scott and haltech and kept asking if it was correct, he said it was. but theyre prob was confusion on both our parts
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Rx7_brad
Aug 15, 2015 09:57 AM
