Fuel Pressure Regulator Rising Rate or not?
Old Feb 5, 2010 | 09:48 PM
douwe's Avatar
just want to no if they worth paying that bit more for any advise would be great thanks
Old Feb 5, 2010 | 11:53 PM
proz07's Avatar
looking for 82-83 corolla
compared to what? are you refering to a 1:1 rise or like a 1:3 rise? two very different versions. the 1:1 is a must for a boosted engine your stock regulator is this. the 1:X style was a long time past way to 'enrich' fuel flow for a boosted engines in the early days which should be discarded asap as the 1:1 with programable fuel injection ECU's gives indefinatly better control.
z
Old Feb 6, 2010 | 03:01 PM
I wish I was driving!
z
1:1 isn't a rising rate, its direct reference. The rate of fuel pressure rise has to be greater that the rate of manifold pressure reference to be a rising rate.
Rising rate regulators are still used quite a bit with supercharger kits, in the 8:1-12:1 range, typically called FMU's. The problem with them is the amount they increase the fuel pressure... at 40 psi base, 10 psi of boost with an 8:1 FMU, your line pressure is going to be 120 psi! This lowers fuel pump flow output, decreases fuel injector spray quality, and puts a lot more strain on the fuel system seals.
There is very little use for a RRFPR on a car with a tunable ECU. There are too many drawbacks too them, and really only compensate for injectors sized too small.
Snoopy FD
Dec 8, 2015 01:45 PM
86glxNA
Aug 22, 2015 08:54 PM
