na rotors
I cant seem to find pics right now, I used to have a bunch. But, S5 rotors will have machining marks all around the faces. Like very fine lines running from apex to apex. The S4 ones will not have this, and usually the combustion chambers will be cast a bit bumpy and uneven. And I would wait to get verification from someone whose dealt with FC engines more recently than I (Its been a while), but I think that looks like a S5 block, no EGR, etc..
so that means if i were to run engine in my fc i would have to run premix right? the guy that sold it told me it was an s5, but i highly doubt it is im sure its just an engine thats a mix of parts, im hoping it at least has the s5 rotors. imma take it apart to see if they are s5 or not
Trending Topics
this engine that i bought was suppose to be s5 but its not only thing s5 on this piece is the center iron and the housing have coolant seals and the irons are 6port so those have coolant seals so the person who built this engine used double coolant seals and was missing one oil control ring, so i doubt this engine ran like the seller told me... and the side seals are stuck and flat so i dont think it even had compression...so i got ripped off and scammed in to thinking it was something its not.... im hoping that atleast the rotors are s5 so i can use the but one of the rotors is seized on to the e shaft..and they were mixed match rotors one a B and the other is a D so i cant even use them together
looks like a hybrid motor with GSL-SE rotor housings and fuel injected S4-S5 irons. i'm guessing his housings were worn and he opted to use the wrong ones, the chrome is much weaker on the early 13B engines.
edit: double coolant seals? man, what people will do these days to try and get some $... be sure to post his info in the "bad guy" section.
you got ripped
so for those of u who are thinking of buying something from hooksrotary dont do it he also goes by rotary hell on craigslist
well i got lucky a few weeks ago and found an s5 motor in the junkyard i opened it up to see what it looked like inside everything looks fine except for the bearing and apex seals so imma do a complete rebuild on the motor my only worry is that when i found it had water inside the rotor housings and it looks as tho one of them has been damage by it and i would like to know if its still usable here are a few pictures of the rotor, it doesnt seem to bad to me but i could be wrong i dont know if it could cause hot spots or something of that sort here are the pics
20B Forum
Sep 22, 2015 07:39 PM
