made a chart of each stock engine's port duration/overlap
Old Jan 30, 2010 | 09:39 PM
arghx's Avatar
rotorhead
Here's a chart with the duration and overlap for series 4 Rx-7 through Series 2 Rx-8, including 4 and 6 port engines:
I used this calculator: http://www.wallaceracing.com/camcalc.php
and here's the source material:
series 4
series 5
series 6
series 1 and 2 Rx-8
Attached Thumbnails made a chart of each stock engine's port duration/overlap-duration_chart_2.jpg   made a chart of each stock engine's port duration/overlap-duration_chart_1.jpg   made a chart of each stock engine's port duration/overlap-s4_duration.jpg   made a chart of each stock engine's port duration/overlap-s5_duration.jpg   made a chart of each stock engine's port duration/overlap-s6_duration.jpg
made a chart of each stock engine's port duration/overlap-renesis_duration.jpg
Old Jan 31, 2010 | 08:36 PM
j9fd3s's Avatar
Community Builder
sweet! i did that on the last HD, but i looked up the timings of the early 10a, and the PP's as well.
since its lost, i don't recall exact numbers but the PP is like 330/303 or something, its like the rx8 in terms of the intake/exhaust timing relationship.
Old Jan 31, 2010 | 11:36 PM
arghx's Avatar
rotorhead
where'd you get the information for the 10A and PP motors? Is there some kind of service manual or Mazda document you found?
Old Feb 1, 2010 | 11:45 AM
j9fd3s's Avatar
Community Builder
both, some was in the FC yamaguchi book, and i have a bunch of old manuals around too, google..
actually http://foxed.ca/foxed/index.php?page=rx7manual he's added some new ones
Old Feb 1, 2010 | 09:41 PM
Black91n/a's Avatar
Are you sure that "ATDC" means "AfterTDC" and not "AboveTDC"? It seems odd that there'd be such a large difference in the port durations between the FC and FD motors when the ports don't look that much different.
Old Feb 2, 2010 | 02:43 AM
quattro4now's Avatar
This thread should be stickied.
Old Feb 2, 2010 | 11:54 AM
j9fd3s's Avatar
Community Builder
the timings are given like its a camshaft, so its AFTER tdc, like a cam.
you're right though, typo on the FD?
Old Feb 2, 2010 | 01:06 PM
diabolical1's Avatar
this is a great thread, man. i like it. let me just say thanks for taking the time to compile and post your chart.
nice catch. according to the other documents posted, they are identical open and close timings.
Old Feb 2, 2010 | 04:20 PM
nillahcaz's Avatar
you are missed
More port timing data
visual port timing
Old Feb 6, 2010 | 09:21 PM
arghx's Avatar
rotorhead
They're very different. Read through it all again, the FD opening is very different because it is in BTDC, not ATDC. Put the numbers into the calculator I used.
I thought it was a typo myself, but I cross referenced all the sources and the numbers were the same. The FD port timing is much different from the FC turbo motors. I wish I had specs on the Cosmo 2 and 3 rotor engines.
93 FSM
93 service highlights
94 FSM
Attached Thumbnails made a chart of each stock engine's port duration/overlap-fd_timing_93_fsml.jpg   made a chart of each stock engine's port duration/overlap-fd_timing_training_manual.jpg   made a chart of each stock engine's port duration/overlap-fd_timing_94_fsml.jpg
Old Feb 7, 2010 | 08:30 AM
arghx's Avatar
rotorhead
just looking at some of those other links that have been posted here... all those other sources seem to think that the opening time of the FD ports are similar to the FC ports, even though the service manuals say otherwise.
And here is a diagram out of the Renesis SAE paper, and it lists the FD as having 16 degrees of overlap (just like the 13BT). So maybe it was a typo that was propagated throughout Mazda's documents at the time.
Attached Thumbnails made a chart of each stock engine's port duration/overlap-renesis_overlap.jpg
Old Feb 7, 2010 | 01:36 PM
j9fd3s's Avatar
Community Builder
ask and ye shall receive
can't believe i missed the ATDC/BTDC changeover though...
Attached Thumbnails made a chart of each stock engine's port duration/overlap-cosmotiming.jpg
Old Feb 7, 2010 | 08:27 PM
I wish I was driving!
FSM for the FD is wrong. It should be in values of ATDC, not before. Degree wheel don't lie.
Old Feb 9, 2010 | 07:39 PM
arghx's Avatar
rotorhead
^ I'm just surprised that the 93 FSM, 94 FSM, and service highlights are all wrong
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
