new to rx7....help
Old Jan 26, 2010 | 08:00 AM
Skadaloz's Avatar
Cool new to rx7....help
alrite im well known into honda...but new to rx7...my buddy has a 91 rx7 turboII...its been sitting for a couple years now...got the motor rebuild(apex seals, etc..) and he got it back in and it wont start...we got it started then he drove around the block and parked it and now it wont start...when it was running if we plug the maf sensor in the car would die..so we ran it with the maf senor unpluged...but yea that was 2-3 yrs ago...well now hes goin to give me the car(i work on it and i drive it for a year then give it back to him)...but i have no clue...to me it seems that the car is flooded, timing is off, and has electrical issues...so any anyone help me out?
Old Jan 26, 2010 | 10:57 AM
Aaron Cake's Avatar
Engine, Not Motor
The car won't run with the AFM unplugged.
Since the car has been sitting for several years you have some work ahead of you.
Finding the original problem is going to be hard.
Start here:
http://www.aaroncake.net/rx-7/unstore.htm
Swap a different AFM onto the car.
Old Feb 5, 2010 | 02:04 PM
Skadaloz's Avatar
PA
well i just got some info that the other owner b4 my friend hacked up the engine harness...so how much does a stock 91 turbo2 harness go for...i dont have that much money as of now(too many tickets and my job only pays min. wage)
Old Feb 6, 2010 | 10:54 AM
Aaron Cake's Avatar
Engine, Not Motor
Find a used harness via the classifieds section. The cost will be anywhere from free to a few hundred dollars.
A new harness at the dealer approaches $1000.
Old Feb 7, 2010 | 04:34 PM
Skadaloz's Avatar
aite ill keep searhin to see if i can find any...
Old Feb 7, 2010 | 04:36 PM
Skadaloz's Avatar
im also looking for a maf sensor just in case the one on it is bad
Old Feb 7, 2010 | 04:47 PM
Skadaloz's Avatar
just wondering if an s4 engine harness and maf will work on my 1991 rx7 turbo2(im guessing its a s5, correct me if im wrong)
Old Feb 7, 2010 | 05:03 PM
DI2CCO's Avatar
POWERHOUSE
the s4 harness will not work your best shot is an aftermarket ECU with harness like Haltec etc.. or get someone that really knows what there doing to wire. However 91 Rx7 TII is a great gift and spending a little money should not hurt.
Good Luck
Old Feb 8, 2010 | 12:01 PM
Skadaloz's Avatar
well...i guess ill just have to redo the engine wiring harness(done plenty on hondas) but then again im getting lazy nowadays...plus too cold and too much snow to b workin outside....ill wait til spring comes
Old Feb 9, 2010 | 03:54 AM
Seamoan's Avatar
Leaking FC
my car was sitting for 3 years and i started taking it apart without checking fuses check your fuses dude! now the car runs good
