My 12a won't start
Old Jan 24, 2010 | 05:00 PM
boricuasinmiedo's Avatar
rotary vs piston!
My 12a won't start
my 85 12a won't start, I checked the spark plug wires with the sparck plug on one of the strut tower bult one by one and they all lighted up. then dump some oil down the carb and won't start. so guys tell me what else can it be
Old Jan 24, 2010 | 06:48 PM
Pele's Avatar
Right near Malloy
Is fuel getting from the tank to the carburetor?
Old Jan 25, 2010 | 09:38 AM
Kentetsu's Avatar
If you have good spark, and you have gas, then it is probably just flooded. Pick up some Seafoam and dump an ounce or two down the carb, then try starting it. That will usually do the trick....
Old Jan 27, 2010 | 05:39 PM
Aerodynamic Pants's Avatar
is your timing set properly?
Old Jan 28, 2010 | 04:38 PM
rotary vs piston!
yes there is gas going to the carb. and yes the timing is good one thing forgot to mention was that I had bad carb in it and bought another one and it started like a brand new car but then I try to started again and since then and nothing. but Kentetsu I'm going to try that! and if any body knows any thing else please let me know, thank's
Old Jan 30, 2010 | 10:33 PM
thatguy23's Avatar
iv done the seafoam thing before it worked
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
