Newbie with questions
Old Jan 19, 2010 | 03:00 PM
ALMACK's Avatar
KY Newbie with questions
Hi.
I got turned on to the Gen 2 RX7 by a friend of mine so I am trying to learn about different abbreviations, year changes, etc.
I am interested in buying a 88 GTU. I heard the TII versions had 4.11 gears and a factory style posi/traclok (whatever it is called)
Did the '88 GTU come with a better rear than a std. RX7 ?
Also, what does S4 and S5 stand for ?
Is there a section for engine swap builds, info, etc?
Thanks,
Alan
Old Jan 19, 2010 | 03:12 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The standard specs thread will help you with most of your questions. It's a sticky at the top of this section: https://www.rx7club.com/new-member-rx-7-technical-256/specifications-what-did-2nd-generation-rx-7-come-w-options-standard-features-782409/. Models with LSDs are listed. Many NA models had 4.1 LSD rear ends; it was not just on TIIs.
You can browse the generation specific and performance/tech sections for information on engine building and swapping.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
