Carb/Intake Questions
Old Jan 18, 2010 | 11:25 PM
joemaddox's Avatar
From: Philomath Oregon.The five whole blocks of it!
I am getting togeather the last of the parts i will need for my turbo FB build.... I am only needing a carb/intake and a few other small things to be good to go, but i am stuck on what set up to get.....
Ok, so IDA is looking much cheaper and more available, but i have been told that a side draft set up is better for boost applications....
So what does everyone think, IDA or Side? What are the benifits over IDA what are the problems that side draft will cause,ect... Pretty much every though, opinion, experience or option you can think of telling me about i want to hear it!
Also i cant seem to find a company that makes lower intake manifolds for the 86-up 4ports...... I find lots of top pieces but i have been told that they will not fit the stock lower intake, so i am at a loss there as well.
HELP ME PEOPLE I CANT FIGURE OUT WHAT TO DO
On another note, the "purple pounder" is now in the shop and starting its new life soon to be somthing else entirely!!!
Old Jan 19, 2010 | 01:55 AM
installer67's Avatar
Dreamin of drivin my 7!
I'm not a turbo guy but....
I'm not a turbo guy, but it's my understanding that the longer intake runners, positioning and easy access, make a side draft a good candidate.
PS- really pricey, but heres a side draft intake for a 13b 4port
http://www.mazdatrix.com/getprice.as...um=C-WEBER-13B
Old Jan 19, 2010 | 02:24 AM
joemaddox's Avatar
Ah ha! Ok, this is what i was looking for :
http://www.mazdatrix.com/getprice.asp?partnum=18112
Now to find a carb set up :\
Old Jan 19, 2010 | 02:29 AM
Talk to Kerebrus. He's had some OER sidedrafts for pretty cheap.
Old Jan 19, 2010 | 02:41 AM
I believe Trochoid has a mikuni still for sale too.
If you end up going weber dcoe, look here https://www.rx7club.com/forum/showthread.php?t=882842 I put up a **** pot of info on the dcoe, specs etc. and pm me if you want the weber service manual. I have it in pdf.
Old Jan 19, 2010 | 11:28 AM
RW-7's Avatar
Moderating the Trochoid
Most companys that make or made an intake setup for aftermarket carbs never made a setup for the turbo motor. My guess is that for this application most people ran a fuel injection setup for a turbo motor. The tunability of a FI vs. a Carby is much more doable and controlable with FI, and as touchy as the rotary is when boost is applied the logical choice was usually FI with some sort of tuning options.
So Joe, have you considered a fuel injection setup?
Old Jan 19, 2010 | 01:14 PM
joemaddox's Avatar
I just cant stand the throttle response of any EFI system, and i dont have the thousands to put into the car to uprgade the system to the point where that is gone. I love my carbys
So i just want the best carb set up, i'm not looking to take ferrari's
Old Jan 19, 2010 | 04:01 PM
Bearzah's Avatar
Me Wantee Da' Boostee
Originally Posted by joemaddox
... i'm not looking to take ferrari's
At least STI's and Corvette's will FEEL YOUR WRATH !!!
Brap Brap Brap... BRRAAAAAAPPPPPP... ppsssshhhhh. GET SOME!!!
Old Jan 20, 2010 | 10:42 PM
Kill No Cone's Avatar
Ask Hyper4mance2k, he has done it...
blow through carb, ya...
IDA, yup he has done one.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
