3k startup
Old Jan 18, 2010 | 04:32 PM
bostonspgs's Avatar
Boston Acoustics SPG555's
3k startup
Drove my car to work , no probs(cept the 3k startup doesnt happen so i accelerate to 3k then let her warm up.)a friend drove it then another stalled and flooded it. had it towed yesterday cus even after deflooding procedures she woulnt start. today i hopped in it and she fired up and went 3k (on its own) then stalled. kept retrying and as soon as it hits 3k or you touch the gas she stalls. also broke the inside switch on the ignition switch by turnin the switch with a screw driver (its not bolted to the ignition) is that gonna mess up due to the factory alarm?
Old Jan 18, 2010 | 09:32 PM
funkjaw's Avatar
Try reorganizing your question into a more legible one.
Old Jan 18, 2010 | 10:01 PM
bostonspgs's Avatar
Originally Posted by bostonspgs
1Drove my car to work , no probs(cept the 3k startup doesnt happen so i accelerate to 3k then let her warm up.)a friend drove it then another stalled and flooded it. had it towed yesterday cus even after deflooding procedures she woulnt start. today i hopped in it and she fired up and went 3k (on its own) then stalled. kept retrying and as soon as it hits 3k or you touch the gas she stalls. what should i search for and how come my accelerated warmup doesnt work
2also broke the inside switch on the ignition switch by turnin the switch with a screw driver (its not bolted to the ignition) is that gonna mess up due to the factory alarm?ie is it gonna lock me out? is it gone shut down the starter ? possibly mess with the ecu
sorry about the constant random not understandable questions but i got adhd and it takes a lil bit(maybe alot more) of concentration for me to word things properly. and i only ask the second question because it went into a lockout procedure ie lights and every thing shut off when i messed up the ignition switch
Old Jan 19, 2010 | 01:28 AM
funkjaw's Avatar
If the car is dying 3k rpm or below it is typically caused by a vacuum leak.
No your ignition will be fine there is no mechanism to lock you out or shut down the starter.
Old Jan 19, 2010 | 05:26 AM
InsomniacFC's Avatar
Will drive for parts
^^^ That or the previous owner did the throttle body mod.
sherff
Feb 24, 2019 12:09 PM
SupraKiller
11
Jun 5, 2002 06:19 AM
JoelChicago
Mar 26, 2002 10:51 AM
whitekingsnake
11
Oct 19, 2001 05:09 PM
rxse7en
Sep 7, 2001 09:00 AM
