rx7 idle prob
Old Jan 18, 2010 | 03:02 PM
rotor1991's Avatar
rx7 idle prob
well my rx7 will idle fine as long as no electricals are on. when my hedlights get turnd on my idle drops almost to 0. or when my sub hits or any electrical thing is turnd on my idle drops my volts are staying at about 14 like they should i cant figure it out. any help or ideas thanks
Old Jan 19, 2010 | 10:28 AM
jjcobm's Avatar
Are you experienced?
Try checking the Idle Air Control valve, or BAC. Not sure what series 7 you have but you are basically looking for the valve that supplies air for idle and load. If you are missing it or it isn't working correctly, your car will die with electrical loads or idle weird... Usually located on the Intake Manifold....
Kyo
Apr 13, 2019 09:24 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
ncds_fc
Aug 15, 2015 10:06 AM
