Canadian Forum Canadian users, post event and club info here.
water injection question
Old Jan 15, 2010 | 10:11 PM
gkarmadi's Avatar
water jacket mod??!
Hi all,
I am trying to install a water injection kit this winter (pre turbo system) and i was just wondering if there is any precaution i should know about. This will be my first water injection kit.
Can i drive the car after the installation (in spring) without any tuning?? should i turn down the boost?? The injector is relatively small (only 150cc) and I'll be running stricly water (distilled).
thank you in advance
Old Jan 16, 2010 | 08:13 AM
Double_J's Avatar
Water does not impact tune from what I understand. You should be perfectly fine. If you were running methanol then you would need to adjust your tune.
Depending on your setup I am sure many people in the aux section would advise on running more water pre turbo.
https://www.rx7club.com/auxiliary-injection-173/
Old Jan 16, 2010 | 08:47 AM
thewird's Avatar
It will not affect your tune. However, I noticed on a car that I tuned that the AFR read 0.1-0.2 points leaner running with the water on. I did back to back tests with the water on and with it off and the results were always the same. Since I tuned the car safe to run without the water to begin with, I made no adjustments to the tune with the water.
So the answer to your question, you can add it and make no adjustments to your tune whatsoever. The only adjustments would be if you were relying on the water to make more power with a more aggressive tune (more boost, more timing, leaner AFR).
thewird
Old Jan 16, 2010 | 10:20 AM
Double_J's Avatar
I'm sure there are countless ways to tune and so what I say should be taken with the smallest grain of salt but other believe if you are running just water you don't change anything other than boost. I can't remember his sign on but RC24 something seems to have done well with this method.
I believe he was even running pretty rich afr's too but I haven't read the thread in some time.
Old Jan 16, 2010 | 10:37 AM
bsecured's Avatar
thewird
Any noticeable different in hp/tq curve with the water on?
Old Jan 16, 2010 | 10:43 AM
thewird's Avatar
Originally Posted by bsecured
Any noticeable different in hp/tq curve with the water on??
Car was never dyno'd. The owner just wanted a reliable daily driver which was the reason for the water.
I had a theory, that it might just have been the water that turned to steam and since water contains oxygen and widebands read oxygen, that was the reason for the leaner AFR's. I even tested turning on the water midpull and the AFR changed instantly.
thewird
Old Jan 17, 2010 | 09:00 PM
gkarmadi's Avatar
water jacket mod??!
thanks everyone for info...weather been good in the past few days (almost done w/ the install).
Old Jan 19, 2010 | 05:15 PM
fdz4me's Avatar
How difficult is the install? I am interested in runing WI in my FD.
Old Jan 19, 2010 | 05:16 PM
thewird's Avatar
Depends on what system you buy.
thewird
rotor_veux
Sep 3, 2015 07:10 PM
