speedometer
Old Jan 11, 2010 | 01:09 PM
bostonspgs's Avatar
Boston Acoustics SPG555's
speedometer
So I have an 87 tII but amongst other probs my speedo wont move at all . i took it apart and the clip for the speedo looks like its missing something . the clip looks like a bearing but the thing it clips onto is a bearing. is there supposed to be a shaft in the middle connecting the two?
Old Jan 11, 2010 | 03:36 PM
Aaron Cake's Avatar
Engine, Not Motor
I'm not quite sure what you mean in your post, but it sounds like the speedometer cable may be broken.
On the cluster end, inside the white connector, there should be a square wire which plugs into a square hole on the back of the cluster.
On the transmission end, there is a round wire with a flared flattened section. This mades up with a slotted shaft inside the transmission.
Old Jan 12, 2010 | 06:21 PM
bostonspgs's Avatar
there isnt any thing inside except a hole and some grease , does the square wire go all the way to the tranny like a weed wacker? im just wonderin cuz i was thinkin about takin an allen wrench and cutting it .
Old Jan 12, 2010 | 11:11 PM
chuuchrx7's Avatar
i agree with arron cable might be broken.
Old Jan 13, 2010 | 03:36 PM
Aaron Cake's Avatar
Engine, Not Motor
Get a new cable.
Old Jan 13, 2010 | 03:54 PM
bostonspgs's Avatar
yah its only 21 95 ebay. thanks
