r1 or r2 springs with koni yellows
Old Jan 10, 2010 | 11:56 AM
ManGaZeRo's Avatar
Living the Dream
I finally able to secure some koni yellows. Now I am at the predicament of whether to use r1 or r2 springs. I know the r2 are a bit softer than r1s but just wanted to hear everyone's 2 cents.
Old Jan 10, 2010 | 01:12 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
no predicament as all FD USA 93-95 springs are the same. the diff is in the dreadful R series shocks.
howard coleman
Old Jan 10, 2010 | 01:46 PM
ManGaZeRo's Avatar
Living the Dream
ha... thank you, mixed up the info. Been out of the rotary game for awhile
Old Jan 10, 2010 | 08:45 PM
jmadams74's Avatar
When I went with the Koni yellows, also went with the Eibach Springs. Many years on this setup and still very happy. Also added RB sway bars at the same time. Not a race car setup, just very nice handling!
Old Jan 10, 2010 | 09:23 PM
ManGaZeRo's Avatar
Living the Dream
are the front shocks inter changeable for left and right?
Old Jan 11, 2010 | 08:49 AM
adam c's Avatar
Cheap Bastard
howard coleman
Its been a while since I looked into this. As I recall, they are not the same.
Old Jan 11, 2010 | 09:16 AM
"Koni yellows, also went with the Eibach Springs. Many years on this setup and still very happy."
that is a no brainer killer combo. do not discount this option.
"are the front shocks inter changeable for left and right?"
no
hc
Old Jan 11, 2010 | 10:26 AM
ALPSTA's Avatar
Mission Impossible
Front shocks have different part numbers for L & R, rear shocks have the same part number
Howard, there is a set of Tein (assuming S-techs) springs available from a guy in my country. What do you think of Koni + Tein S-tech set-up? Otherwise I might have to look into having Eibachs imported which will cost more and take longer.
Old Jan 11, 2010 | 12:08 PM
"What do you think of Koni + Tein S-tech set-up?"
Eibach Pro Kit 350 Fr/ 255 R
S-Tech 440 Fr/ 320 R excellent rate
S-T lowers the car 1.4 inches fr and 1.3 r which is fine. you will need to reset your camber. pls set your car to my specs and don't forget tire pressure.
hc
Old Jan 11, 2010 | 03:40 PM
ALPSTA's Avatar
Mission Impossible
Ok, will do, thanks
Old Jan 11, 2010 | 04:39 PM
tabuk1!'s Avatar
Hey Howard,
with the Eibach/Koni setup - how far from stock ride height can you go..? And, if you wanted to, could you keep it at the stock ride height -or- is that not possible?
thanks
dave
Old Jan 12, 2010 | 01:34 AM
Pdaddy43's Avatar
hey if you want dome R2 springs ill sell them to you for a $100 there just sitting in my garage
Old Jan 20, 2010 | 02:46 AM
I own an R1 with Koni yellows. Will the Eibach springs give better bump compliance/ ride than the stock R1 springs? Or are they harsher? Also, do they change ride height much, or at all? Howard, I just asked you this in your sticky but then I found this thread, sorry.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
inMotion719
Sep 28, 2015 03:09 PM
