intake lingo
Old Dec 26, 2009 | 10:25 PM
joemaddox's Avatar
From: Philomath Oregon.The five whole blocks of it!
intake lingo
Ok, so i can guess all day, but i am not positive and i am getting "mixed" acronym from google.... so.....
DCOE
DHLA
IDA
Ect......... what does all this mean...? Like i said i can guess and think dcoe can mean duel carb over engine and what not but am i even close?
Thanks
Old Dec 26, 2009 | 11:09 PM
installer67's Avatar
Dreamin of drivin my 7!
I've wondered the same thing!
Old Dec 26, 2009 | 11:16 PM
Came across this ....... hope it helps.
DC - doppio (double) corpo (body) i.e. twin choke
O - orizzontale (horizontal) i.e. sidedraft
E - indicates carb is die-cast
Old Dec 27, 2009 | 01:03 AM
PercentSevenC's Avatar
I need a new user title
They're model designations for various carburetors. Here are some of the ones I've seen used on rotaries.
Webers:
IDA = 2-barrel non-progressive downdraft
IDF = 2-barrel non-progressive downdraft, somewhat different design from the IDA with a different bore spacing
DCD = 2-barrel progressive downdraft, used in pairs in an old Rotary Engineering setup
ICH = 1-barrel downdraft, used in RotaryShack's high-MPG carb kit
DCO = 2-barrel non-progressive sidedraft
DCOE = same as DCO except with a cold-start enrichment circuit
Dellorto DHLA: improved copy of the Weber DCOE
Mikuni PHH: improved copy of the Weber DCOE
OER: improved copy of the Weber DCOE (seeing a trend here?)
Then there are the various big 4-barrels, such as Holley, Edelbrock/Carter, Demon, etc., which share a common manifold style.
Old Dec 27, 2009 | 01:23 AM
joemaddox's Avatar
awsome! This is the info i needed guys! Thanks
Old Dec 28, 2009 | 09:08 PM
Hyper4mance2k's Avatar
The Shadetree Project
e= choke, not die cast. Gavin improved should be in quotations. OER’s are just Weber rip-offs. Mikuni's and Delorttos were supposed to have improvements on the transition circuits and easier to understand jetting schedules. I like real Webers best out of them all.
Old Dec 28, 2009 | 10:34 PM
You're right, I should've put it in quotes.
OERs do have a few nifty features, like externally adjustable float levels and adjustable accelerator pump stroke, and they come boost-prepped from the factory. Otherwise, yeah, they're basically just DCOEs. They're even compatible with DCOE jets and e-tubes.
