Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Timing Spreadsheet
Old Dec 24, 2009 | 01:18 PM
solareon's Avatar
Timing Spreadsheet
Hey Folks,
I created this timing spreadsheet to help you better visualize the boost based timing maps used on the S4 Rtek 2.1. On the input page you plug in your timing maps (included in the sheet is a safe boost based timing for S4T2 Streetport and what I currently run) It will allow you input Leading, Trailing, and Split timing.
Timing values are highlighted depending on their value. I don't know if the scale I used is accurate but here it is below
Leading & Trailing
-15 to 0 = Green
0 to 15 = Light Orange
16 to 25 = Dark Orange
26+ = Red
Split
15 to 10 = Green
9 to 5 = Dark Orange
4 to 0 = Red
On the calculated page you can see if the values you input are correct (it's a very simple check atm, please let me know if you see room for improvement here) and if you didn't input a map on the first page it will calculate it on the second page.
If you see any features you would like me to add or if you see something incorrect let me know via pm or this thread. If you edit the rows or column labels on the input page they will move to the other page. Also the calculations page is locked but with no password. I will be working on a fuel calculation spreadsheet soon as well to make your fuel corrections easier.
You can download the spreadsheet here
Legal BS:
I am not a tuner or certified car mechanic. The above spreadsheet is for informational purposes only. If you blow up your engine, ecu, or car I'm not liable. If you crash into somebody while trying to use the spreadsheet while driving I'm not liable. Etcetera etcetera
Disclaimer of Warranty
The services, information or data (collectively, "Information") made available in this post are "AS IS," without warranties of any kind. I expressly disclaim any representations and warranties, including without limitation, the implied warranties of merchantability and fitness for a particular purpose. I shall have absolutely no liability in connection with the services including without limitation, any liability for damage to your person, car, engine, ecu, and etc. resulting from the Information or the lack of information in the above post.
I shall have no liability for:
Any loss or injury caused, in whole or in part, by its actions, omissions, or negligence, or for contingencies beyond my control, in procuring, compiling, or delivering the Information;
Any errors, omissions, or inaccuracies in the Information regardless of how caused, or delays or interruptions in delivery of the Information; or
Any decision made or action taken or not taken in reliance upon the Information furnished above.
I makes no warranty, representation or guaranty as to the content, sequence, accuracy, timeliness or completeness of the Information or that the Information may be relied upon for any reason. I make no warranty, representation or guaranty that the Information will be uninterrupted or error free or that any defects can be corrected.
Attached Thumbnails Timing Spreadsheet-input.png   Timing Spreadsheet-calculations.png
File Type: zip
Old Dec 25, 2009 | 11:08 AM
Nick_d_TII's Avatar
Question
I'm not sure what this spreadsheet 'calculates'? If you wanted to calc. split it's just leading - trailing.
It seems your color scale is off? I have attached a screenshot of the trailing map and the calc. trailing map, notice the different colors, but the numbers are the same.
I tried lets say '10' on the leading map at the first cell (16psi @ 1024rpm) leaving trailing and split alone. Going to the calculated sheet, it says can't calculate? OK, I'm confused. More info. please.
Old Dec 25, 2009 | 02:44 PM
solareon's Avatar
Well I made it just so people could plug in timing maps and it would calculate either the leading trailing or split depending on what they plugged into it. I may have messed up on the colors in the sheet. It's on my laptop at home so I'll fix it and post an updated version.
The can't calculate bit is there so that if you input all 3 maps then it checks what you put in versus what it calculated. If they don't match it flags them to let you know to recheck. Excel may not be the best for a verification but it was easy and will flag your values if you made a mistake. I will correct this as well as showing if an individual cell can or can't be calculated. Right now that check only works for the leading calculated map.
I think it would be useful for copying maps from people with powerfcs and then getting them to align with what the rows and columns in the rtek are versus doing it on the fly. You can also input in two maps each in a different copy of the sheet and then compare them to see roughly how much different the timing is between them. If people would like that feature enhanced I can put that in as well. I didn't know if anybody else would find it useful but I figured I would share it.
Edit: The new update will be in xlsx format because it support much better shading of the cells that look much closer to the power fc
Old Dec 25, 2009 | 03:13 PM
Nick_d_TII's Avatar
Ok, that makes sense. What would be cool if we could get our saved maps exported to excel then modify them there. and then import them. But I see what your saying about comparing to powerfc maps. I think the color makes it better to see the smoothness in the map so thats pretty helpful too...
Are the maps on the power FC layed out differently though? Good job tho..
Old Dec 26, 2009 | 07:28 PM
turbo2ltr's Avatar
I dont have Excel (I use Open Office). Does excel allow you to save the spreadsheet as an XML file?
Old Dec 27, 2009 | 10:23 AM
solareon's Avatar
i believe that excel 2k7 does. I am going to put an updated spreadsheet today.
Old Dec 27, 2009 | 08:10 PM
solareon's Avatar
new version attached.
Changes:
It will now show NaN for any cell it cannot calculate.
If all numbers on the input tab match the calculated value it will show "Verified" below that table" if not it will show "Not Verified"
Colors are now gradients of red yellow green to match the powerfc view. On Leading & Trailing <0 = green 25 = yellow and >50 = red. Split is set that 0 = red 7.5 = yellow and 15 = green. If this is not accurate please let me know so I can correct it.
Compare tab added. Input a different timing table here and it will show you the difference between where you are on the Difference tab. The color scale on the difference tab is <0 = green 5 = yellow >10 = red.
XML sheet attached. No colors in the XML sheet though due to it not supporting the gradient style shading.
Heres an updated screenshot.
Download Here
File Type: zip
Old Dec 31, 2009 | 05:46 PM
Nick_d_TII's Avatar
So I was testing this because I find it interesting and I still don't get it? or it just isn't working as I thought it would.
On the input map at cell B5 (16psi @1024rpm) I put 12, so on the compare map I put 12 in the same cell then went to calculated and it says can't verify on all maps??? But it does appear to have updated the Split map on the Calc. tab. but it says 27 for split? (12-15 is 27)
But on the input and compare tabs where I put 12 for the cell 5B it didn't do anything on the split maps there?
Difference all equal 0.
Test #2
I put 100 on the same cell of the split map on the input tab. No changes to the trailing or leading maps on the input tab. No changes on the compare tab. Difference map has split cell in red that I changed.
Now the Calc. Tab has 85 for that cell on leading and -100 on the trailing. But says can't verify.
That should make my split like 185??
Aha! So If I put 12 in cell B5 on the input tab, and correct the split to be 27 on the input tab then on the calc tab it says verified. So I know that my trailing and leading values match my split values and the difference from the Compare Map.
So here's what I suggest. I like to see leading timing and split maps. Trailing not so much. Well for me its easier to understand one plug firing(leading) then then the degrees until trailing fires(split). If I made a calc it would have leading locked as a number, then input the split and then calculate split minus leading to give what trailing should be. But the RTEK you can input either and it will correct the split or trailing. (you input split it changes trailing)(you input trailing it changes the split)
I think, like you said the colors are really nice to have for those comparing to PFC maps. And to visually see how the map is layed out. I'm going to 'compare' this map to the map I inputted and I'll let you know how it works. I did save it back to .xls and it seems to be working fine? said it may lose some functionality or something.
Old Dec 31, 2009 | 06:02 PM
Nick_d_TII's Avatar
Your using ARGHX's map from https://www.rx7club.com/showpost.php...8&postcount=15
Here's the one I used, well I went about -1 degree across the board.
https://www.rx7club.com/showpost.php...4&postcount=30
What did you do with the extra row? On the palm there are 19 rows.
Old Jan 1, 2010 | 12:57 PM
solareon's Avatar
Test #2
I wasn't sure if saving it as an .xls would lose the gradient color shading.
I left all 3 maps in there so that if you get 2 from another source (someone posting a powerfc leading & trailing map) you can put both of those in there and then it will give you a split map.
The verified/not verified bit checks to see if what you input for each table on the first page matches what it calculated to be the correct value based on the other two tables.
Like if you put in 12 for B5 (16psi 1024rpm) on the input tab but the values you have under trailing and split say that it should be 0 it will flag that map as not verified. It also flags the other two as not verified because the leading map is used to calculate those two and they don't match the input tab.
If you clear the trailing map on the input tab and just ignore the verified thing it should work as you are thinking.
on the missing row from the palm I just copied the rows from the arghx sheet. To be honest I haven't looked at the palm timing tables in a long while due to driving my s5na car.
Old Jan 4, 2010 | 09:59 AM
rotarygod's Avatar
Rotors still spinning
Someone please post what the stock maps look like.
Old Jan 4, 2010 | 10:08 AM
solareon's Avatar
the stock maps are load based aka useless. turbo2ltr might be able to get the maps they use for the rtek 1.5/7/8 that do the retard 1 degree per pound of boost.
The map I posted is what I run and works. I drag it up to 16 psi and have been for the past 3k miles. Little laggy with my bnr stage 2 but definitely screams up top
Old Jan 4, 2010 | 10:14 AM
turbo2ltr's Avatar
The retard in the stage 1 is not implemented by an edit of the map but an additional calculation done in real-time on the looked up map value. A dump of the maps in the stage 1 would look just like a stock stage 2.
Old Jan 4, 2010 | 10:23 AM
solareon's Avatar
gotcha that makes sense.
Old Jan 4, 2010 | 05:55 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
solareon, try advancing your timing at low rpm/high boost area another 5-10 degrees.. it will help spool up a lot
Old Jan 24, 2010 | 10:09 AM
Omixeo's Avatar
'89 GTUs
Few dumb questions here, since I know next to nothing about timing.
So I've got a t04e s5 hybrid on my S4 TII with a street port and I've got the rtek 2.0. I'm just about to start tuning it soon, now can I just take one of these timing maps and plug it in? The car runs and drives and is really rich right now, but I haven't changed anything in the fuel or timing maps yet. I don't know enough about timing yet to know if it's safe for me to put this map in there and try it.
Old Jan 24, 2010 | 07:13 PM
solareon's Avatar
These maps are pretty safe base maps to play with to start with. I've been running this map for quite awhile with no issues
Old Jan 26, 2010 | 05:45 PM
Nick_d_TII's Avatar
I really want to understand timing better? I understand It has something to do with flame fronts and flame front propagation and maximum combustion, can someone please clarify this stuff for me?
There used to be a huge timing thread, but I would really like some professional Tuners to give some input, but its like their secret recepie, and they don't want to spill the beans.
Someone please answer these questions...
How does timing affect afr's and egt's? Is there a destinct sound the engine makes when timing is optimal? How can I get optimal timing w/o blowing my engine? If my timing is too retarded can I gain HP by advancing it? How do I know if my timing is too retarded? How does porting affect timing?(street, bridge, pp?) How does compression ratio affect timing? (8.5:1, 9.0:1, 10.0:1) How does timing affect reliability? How does split affect HP? How does split affect flame front propogation(not sure what I'm saying here exactly)?
How do I tune timing? What are good numbers besides 15 degrees at 15 psi?
Thanks!
Old Jan 26, 2010 | 08:22 PM
arghx's Avatar
rotorhead
Yeah that's a map I came up with and originally posted back in page 1 of this thread: https://www.rx7club.com/rtek-forum-168/afr-tuning-methods-827389/ post 15. It's a basemap built from a lot of accepted "conventional wisdom" and my own experience on my T04S and T04R setups I've run. It's intentionally designed NOT to squeeze every last horsepower out of your setup to preserve a safety margin. IMO the highest priority on any modified turbo car is to make the car not blow up while still being fun to drive. Different turbos, porting, fuel quality etc would be reasons to make adjustments to this map.
I tune cars on the side. The funny thing is, you can tell the average enthusiast everything you know about tuning, and they will usually just run the other way and not want to deal with it. The small percentage of people who are serious about tuning their own cars wouldn't have paid you to tune their **** anyway. So I don't have a problem giving my perspective to people who ask.
Here's the first thing you have to keep in mind, and this is really important. It's this idea of diminishing returns or diminishing benefit. If my timing is WAY off, either too advanced or too retarded, then I am going to pick up a significant gain in either power or reliability by advancing/retarding it respectively. But on any engine there's a sort of "gray area." When you get close to what the engine likes, adding/subtracting a degree or two doesn't really do much. You may see three horsepower or some other small gain in response or decrease in knock activity (knock sensor is not loggable on Rtek). Often times people blow their cars up because they have this race car mentality, that every HP matters. When the reality is, when the timing map is "close enough" you'll actually pick up more power by a change in the weather than a change in your tune.
For AFR's, all I will say is that on a practical level you won't see much of a difference in AFR readings from incremental changes in timing. Now in reality, firing the plug earlier or later does affect how well the mixture burns (oxygen content) but usually you won't be able to tell a difference.
For EGT's, generally speaking either "too much" or "too little" timing can raise EGT's. Whatever that means. EGT tuning is actually pretty dicey because nobody can agree on anything and everybody measures in a different way. I have a dual channel digital EGT setup on my car right now so I can actually datalog each rotor. There are so many factors affecting readings though... you can post up your EGT readings on an internet forum and somebody somewhere will say "OMFG YOU'RE GONNA BLOW YOUR MOTOR" and yet there's really nothing wrong with it.
Not really, but there's a distinct sound when it's severely detonating. Trust me on that one
OEM engineers know the engine so well that they create a model and build a timing map from that. But we're not OEM engineers with their level of equipment and proprietary information, we are hobbyists. So what you end up doing is taking some kind of starting point that you know works on certain setups and slowly modify it from there. That timing map posted in this thread is a map I posted, which is based on a map that I run in my own car, which was based on a bunch of other maps I have seen for various setups, which were based on maps that somebody else did, etc. Nobody reinvents the wheel.
I know that's kind of vague, but that's how most timing maps are actually built. A lot of people for example took the base maps built into the Power FC and made some adjustments based on the fuel quality etc. On cars with a factory turbo and flashable ECU (Evo, STi, etc) people start with the factory maps and say "ok I'm going to try to advance/retard this map x degrees in these cells based on these basic tuning principles."
As I said above, if it's way "off" then you may gain a significant amount of HP. But if it's close, you'll gain only a little bit or basically nothing. For example, one time I was on the dyno and I advanced the trailing timing (reduced split) by two degrees at peak boost. And I picked up about 2 hp on the next dyno run. I ended up just putting the timing back to where it was. 2 horsepower? What's the point? I can't even feel that when I'm driving around, why risk a reduction in reliability? You can't be a slave to internet forum sigs ("tuned xxx hp at y boost") and dyno sheets. That's the wrong mentality.
The same applies to tuning the AFR. You can try leaning it out. Once small-medium sized changes in AFR don't do much, I usually undo my most recent change and then leave it alone. Why kill the safety margin for a measly 3 horsepower? There's a reason why factory cars don't blow up and wannabe tuners' cars blow up all the time. It's because OEM engineers overbuild for achievable hp goals and leave significant safety margin--instead of underbuilding, overreaching, and eventually damaging something.
Under what conditions? Tuning timing for WOT performance and tuning for driveability are two different things. For WOT performance, well the first thing I do is I 'benchmark' my timing map. I look at what timing I'm running and then I try to compare it to as many maps as I can find for similar setups. Then you can get on the dyno and add a couple degrees in a few places and see what happens.
For driveability, well there is idle and there is part throttle. Generally speaking you want more idle timing advance the more aggressive your porting is (or your cam(s) on a piston motor). That's because the intake air charge is diluted by having the exhaust port/valve open (overlap between intake and exhaust strokes). But it also helps to have additional timing when more load is placed on the engine (A/C, electrical load, etc). But that's not adjustable on an Rtek really. For part throttle vacuum conditions it can be helpful to advance timing on ported motors if there happens to be stumbling or misfire. Bridge ports and large streetports sometimes need this.
Under boost/heavier load driving, generally speaking you want less timing advance for higher compression rotors. But there are a lot of factors that play into that such as the porting and the fuel quality. I have made 8.5:1 and 9.0:1 timing maps for FD's and FC's, and as long as the setups aren't too different I usually run about 2-3 less degrees on 9.0:1 setups compared to 8.5:1. This is one of those things where you just have to look at a lot of other people's timing maps and then play around on your own.
In my opinion, timing has a HUGE effect on reliability in the sense that people who get greedy tend to reduce their safety margin and risk the motor over the long term. Remember me talking about diminishing returns? You've gotta know when to say "good enough." For example: "conventional wisdom" says to run 8-12 split under high boost. Well I run 15 on my personal car (T04R, 8.5:1 rotors) at just over 16psi boost. 15 split is the exact amount of split Mazda runs on the Rx-8 actually and that car doesn't even have turbo. That just gives me that extra little safety factor. I'd rather rely on the efficiency of my turbo than the aggressiveness of my tune to meet my goals.
What is the main method that OEM's employ to protect the engine? Ignition retard based on the [hopefully accurate] knock sensor--both immediate changes "oh ****, it's knocking! better pull timing" and long term learning "don't run so much timing next time because it may knock again." Read about the highly sophisticated STi knock control system here: http://www.romraider.com/forum/topic1840.html
This is a really good article by Innovate Motorsports on rich mixture with advanced timing vs somewhat leaner mixture with more retarded timing: http://www.innovatemotorsports.com/resources/myths.php . I fall into the latter camp.
On a turbo engine, well it's all a matter of what you get out versus what you put in. How much are you advancing the trailing (reducing split) in order to pick up a few hp? It depends a lot on fuel quality. I've never been able to pick up significant amounts of power from adding split. But there is a belief among many that the trailing plugs are more likely to cause detonation than the leading. And that's part of the reason why I don't like aggressive split on turbo engines. It just seems like too much risk for too little gain on a car where reliability is a big concern. But in the end you may have to just get on the dyno and find out for yourself what the motor likes.
Depends on engine speed and conditions, it's kind of a big question. For example, the Rx-8 actually uses negative split at idle. The firing order is T1 L1, T2 L2. On the FC and FD, the firing order is L1/L2 (waste spark), T1 T2.
In addition to that innovate motorsports article above, start with these threads:
https://www.rx7club.com/single-turbo-faq-122/advancing-timing-high-rpm-101226/ "advancing timing at high rpm?"
https://www.rx7club.com/single-turbo-faq-122/how-many-run-no-split-timing-325400/ "how many run no-split timing?"
Old Jan 26, 2010 | 09:41 PM
Nick_d_TII's Avatar
Woah. Thanks Arghx. Good info!
I've been logging the timing retard perameter on the RTEK with no reading, I assumed that was the knock sensor.
Sorry for the Hijack Solareon!
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
