West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Rotary compression tester needed!
Old Dec 19, 2009 | 08:09 AM
c41250n's Avatar
Exclamation Rotary compression tester needed!
As title, I need to do a compression test, anyone can please let me borrow one or anyone knows a shop or one has it?
Please let me know, anything would help!!!
Thanks!
Old Dec 19, 2009 | 08:34 AM
widebodyseven's Avatar
Formerly widebodyseven
I think you could use a piston engine tester too.
I got mine from autozone.
It worked find for me 100psi+ on each rotor.
Old Dec 19, 2009 | 04:49 PM
c41250n's Avatar
i've tried with the piston engine tester, they don't work very well.
i've done it once with the piston engine tester but have the pin taken out, i just want to test it again with a rotary compression tester before i do anythig to my car.
thanks a lot!
Old Dec 19, 2009 | 06:17 PM
iLikeEatPoo's Avatar
The Great Dick
any mazda dealership should be able to do it for you.
Old Dec 19, 2009 | 11:54 PM
3rd and final 7's Avatar
wheres the water goin?
you can buy 1 for around 250 http://www.twistedrotors.com/
Old Dec 20, 2009 | 06:39 AM
c41250n's Avatar
i dont want to buy one, if i can rent one that is awsome!!
my car is turbo'ed, so cant really bring back to the dealer!!
Old Dec 20, 2009 | 12:10 PM
The Great Dick
your screwed son!
just kidding. seriously though a piston compression tester is fine
First page on google search..
http://www.kaboodle.com/reviews/rota...-engine-tester
Old Dec 20, 2009 | 03:19 PM
c41250n's Avatar
so when you do the compression test, you leave the valve on the compression tester out, and if i have both leading plugs out at the same time when im doing the compression test, will it still be accurate?
Old Dec 20, 2009 | 03:42 PM
Jdrift's Avatar
Sir Jason the Awesome
What's your location..? I'm a Mazda tech at a Mazda dealer. If you'e local to Delaware i'd be happy to help out.
Old Dec 20, 2009 | 08:24 PM
The Great Dick
Yes it will still be accurate. If you think it's just flooded take out your plugs and use a lighter on the plugto see if it's flooded with fuel or coolant. If the spark plug doesn't catch ignite it's coolant.
Old Dec 20, 2009 | 09:01 PM
Jdrift's Avatar
^ lol, that's jacked up man.
Old Dec 21, 2009 | 02:48 PM
c41250n's Avatar
will try to do that!!
i cant bring my car to the dealer.....
actually for the last day i went out, everytime it starts perfect.
ok, here is my situation, i drive a rx8 and my car has the greddy turbo kit. i went on a track day a month ago, water temp got up to 230, ever since that, my car is experience hard start when its hot. My car drives perfect after start, and idle fine, so what could be wrong? Low compression??
Old Dec 21, 2009 | 03:37 PM
There might not be anything wrong with the compression try these test.
http://www.rotaryresurrection.com/2n..._symptoms.html
http://www.rotaryresurrection.com/2n...l_failure.html
http://www.youtube.com/profile?user=.../0/gn40QqKg10s
Old Dec 21, 2009 | 08:26 PM
c41250n's Avatar
my friend did the compression test for me, it reads only 68psi front and 70psi rear, but stock should be around 110psi.
im not sure if something went wrong with the compression test or not!!
Old Dec 22, 2009 | 06:19 AM
Jdrift's Avatar
I'd be weary on using a typical compression tester on a rotary verses a RE tested. ( Like the one I use at work for the 8's) The RE tested is much more accurate and gives you individual chamber readings, and can also do the front and rear rotor at the same time. That way you don't have RPM variences between rotors that woudl otherwise throw off your readings. I looked up the spec lastnight 85 psi is minimum for the FC's. Oh, at try to get your mesurements at 250 rpms ( On a warm engine if you can manage it. But since you can't then do the best ya can. lol. )
Old Jan 31, 2010 | 11:44 AM
c41250n's Avatar
So anybody has one that I can borrow?
Old Jan 31, 2010 | 03:01 PM
c41250n's Avatar
Anyone who can rebuild a renesis in Norcal area?
Old Jan 31, 2010 | 11:30 PM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
Bring it down take a trip to so cal
Old Feb 1, 2010 | 04:16 PM
c41250n's Avatar
Do you guys rebuild renensis too?
Please send me an email with details.
Thanks
Old Feb 1, 2010 | 09:53 PM
The Great Dick
www.lucky7racing.net
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
