This is starting to get fun!
Old Dec 18, 2009 | 07:32 PM
KrazyRX-7's Avatar
1986 Mazda Rx-& Non-Turbo
Ok, so while whaiting for my water pump and thermostat to be shipped i was looking at it and i found somthing weird, i lifted the plastic cover ont he shock tower under the hood (for the first time) and one of the for small nuts (gold in color) was missing, just one of them on one side. i will be ordering a replacement but i wanted to get more advice, i have only delt with piston engines, and only a little on suspension. should i just put the new one on and torq it to what my book says and get an aligment or take off and retorq all 4 of them? Anything would be nice thanks.
Old Dec 18, 2009 | 09:37 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Stock-style shocks right? Replace the nut and I wouldn't worry about it. If you notice uneven wear on the tire, get an alignment, but it's probably not going to do anything.
Old Dec 19, 2009 | 02:55 AM
KrazyRX-7's Avatar
Yea, the car is 100% stock at the moment. thanks!
Old Dec 19, 2009 | 04:17 AM
Jdrift's Avatar
Sir Jason the Awesome
Put some moth ***** under the hood to keep that gremlin from loosening those damn things. Lol. Just kidding. Just when you tighten them, don't break the stud. Every bolt has a torque spec. But as long as it is tight I wouldn't worry about. Good luck man.
Old Dec 19, 2009 | 09:43 AM
rxtasy3's Avatar
some mechanics in these shops will loose or misplace nuts/bolts and just leave them out especially if there's something covering/hiding them and it's not noticeable and the owner will never know.
Old Dec 19, 2009 | 08:12 PM
KrazyRX-7's Avatar
ok, thank you verry much, im on my way to get some moth ***** can have a grimlin running around my car
Old Dec 20, 2009 | 02:06 PM
MKnA's dad's Avatar
^^^^ How are you going to get their legs apart???
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
